Standard F1 3 Speed Trans Rebuild Parts
Old 10-20-2016, 09:47 AM
Cougar54's Avatar
Cougar54
Cougar54 is offline
I have a 1950 F1 standard 3 speed transmission that may need seals, bearings, and synco brass. What is the model number and transmission manufacturer. Where is a good place to pick up these parts?
Old 10-20-2016, 10:04 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Van Pelt Sales is far and away the best place. VANPELT SALES LLC - your ford flathead source since 2006
Old 10-20-2016, 10:05 AM
bhalemail's Avatar
bhalemail
bhalemail is offline
I got all my parts and information from Van Pelt. I even called them because I had a mix and match of used parts from 2 different 3 speeds and needed to make one good one. They were an excellent help over the phone and got me the parts I needed. Very reasonable too. VANPELT SALES LLC - your ford flathead source since 2006
Old 10-20-2016, 10:09 AM
Cougar54's Avatar
Cougar54
Cougar54 is offline
Thanks guys. Do you know if it is a Borg Warner trans?
Old 10-20-2016, 10:23 AM
ALBUQ F-1's Avatar
ALBUQ F-1
It is a B-W (T-86) design licensed and produced by Ford. Most of the parts are unique to Ford, and there are some differences between 48 - mid '51, and mid-51 on. Van Pelt sells a book that is excellent by all reports and it explains the differences, as well as showing all the steps to disassembly/reassembly.
Old 10-20-2016, 02:37 PM
Cougar54's Avatar
Cougar54
Cougar54 is offline
Ross, this is not a top loader but a 3 speed remote shift transmission out of a late model 1950. I thought the t-86 is a top loader . . . I could be wrong.
Old 10-20-2016, 03:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The gearsets, basically all internals, are the same between the side and toploaders. B-W mostly sold toploaders, to IH and other companies. Although the Ford trannies are based on a B-W design, like I said you need to use Ford parts. It could be the changes I referred to were made when they changed the trucks to side shift, worth verifying exactly what you have.
I don't remember exactly when the changes in these Ford trans took place, and yours may not be original. Mac VanPelt can tell you how to identify the differences, either buy the book or call him. As I recall the most obvious change has to do with the splines for the 1 - R gear, but there are other changes less obvious. For instance, the parts book shows all thru '55 using caged needle bearings on the input and the countershaft. Mine is a '52 and has the later style, loose needle bearings. I think that change is one of the ones made in '51.
I fought a problem with the snap ring on the output shaft bearing popping out for 5 years. I called Mac to ask what he knew about it. He thought a minute, then asked if there was a shim on the front of the bearing. I said Yes. He said, for my trans that should have been tossed, that was for the earlier models. I tossed it, problems solved! He knows EVERYTHING about these trannies.
Jimmiej08
12-13-2016 12:37 PM
Cody_1948
18
03-07-2015 10:01 PM
Jasonnoel
04-18-2014 02:05 PM
59JEEPSTANG
01-02-2011 07:50 PM
89ford73
10-20-2008 08:37 PM
Quick Reply: Standard F1 3 Speed Trans Rebuild Parts
