2016 F250 wheels Which ones and what offset?
I have a 2016 F250 and want to buy some 20'' wheels and run 35x12.5x20 tires. Im going to run a 2.5'' levelling kit in the front.
Im trying to find some wheels but am wondering about offset as i do not want to fit flares to my truck and cant have them out past the fender.
From what I can understand +18mm is the standard offset and the stud pattern is 8x170?
How far back to 0 offset can I go before the wheels will stick out past the front fender?
Any pics of your set up would be great too
Factory offset on your 2016 is +40mm. I too did no longer want my tires outside of my fenders due to rock chips. So for my new truck, I found some stock wheels (any 2005 and newer) and powder coated them.
If you must go aftermarket, get the most positive offset possible, at least 24mm. On a 9" wheel, your 12.50's will stick out, but not too bad.
Anyone else with any info on offsets.
From Research i have done in the last few days it would appear 0 offset is going to stick out even past 2'' flares??
Some info say its ok some say the opposite and +18 is safe with a 35 inch tire and 2'' flare.
I cant stuff it up because of my location im buying wheels over the Internet.
Once i buy them they are mine, no sending them back.
