Who Needs a Hotel?!?! Curtian Pics Added
In a couple of weeks I will be taking my 2 youngest to a weekend soccer tournament a few hours away. We end up going to these tournaments 3-5 times a year and I always hate having to spend a few hundred dollars on a hotel room for the weekend. Since this time it is just me and the 2 boys instead of the whole family I decided we were going to make use of the van instead of a hotel room. Not sure if we will be getting a campsite or doing some urban camping.......but the first step is sleeping accommodations. Pulled the 2 back benches and went to work.
Took some measurements and build the first frame. I was able to go 28"x72":
Then I built the 2nd frame to match and left an isle in the middle:
Threw some OSB on top of it so there would be a solid surface for a couple of air mattresses:
My boys showing how they fit on them:
A couple of shots with the doors closed:
I tested one out. They are smaller than a twin bed, but I am able to stretch out and they are wide enough that I don't worry about falling off if I move around. Width wise it feels kind of like sleeping on a couch. They are light and easily installed/removed with 2 people. You can also attach them to each other if you wanted to make 1 larger bed, or remove one if you are solo and want to maximize your interior room for something else. The best part is that it was a little under $50 in materials, so even if I only end up using it once i still come out ahead. And yes, feel free to crack all the "Cheap skate" jokes you want.......I wear it like a badge of honor.
I am sure I will find good and bad things during the weekend of camping out...
As far as stowing them while traveling, I plan on rigging up some brackets to secure the beds to the bench seat brackets.
Could you use some brackets and make a middle piece between the two beds and get one big air matress? Just something to slide inbetween and offer a little support but easy to remove for travel. I don't think many on here would bag on you for saving some cash. Good luck and have fun.
Jayro88, nice workmanship and fine looking young men, I'm sure you're proud of them. I know air mattresses will work, but there is also some foam you can buy that has like fingers on it (it's for laying on top of your regular bed mattress to increase the plushness of it), and it's VERY comfortable. I've done air mattresses and this foam and the foam is a lot more comfortable, just a thought if you run across it somewhere. I like where you're going.
air in there
That OSB can have a few splinters, mainly around the edges, that can cause a leak in your air mattress, especially as the mattress gets slid around a bit..so you might want to either sand and seal the OSB or maybe lay out some thin cheap carpet padding or some kind of vinyl or foam sheets. Also, if that OSB is made outside of USA or Canada, it could contain adhesives that will cause out-gassing, and odor, especially in a hot vehicle sitting in the sun.
Good luck, yeah van-camping can save a LOT of money...
The Air Mattresses I order came in today. Fit pretty well. I used a piece of carpet and a blanket to cover the OSB in case there were any splinters.
I cut some of these out of scrap foil insulation I had. Still Have to make some others for the rest of the windows. If I had time I would make some curtains, but this will do for now.
Tint is light enough you can see the foil insulation some from the outside. When I finally get around to curtains and darker tint it shouldn't be noticeable at all.
I did pick this up since it is supposed to be in the 40's at night and it looks like we won't have electric for my small electric space heater:
And because I don't trust the "Certified Indoor Safe/99.99% Efficient" I got these too:
