8-13-2010 build date good of bad
Sorry to be asking so many questions. I am shopping for a 6.7 dually and came across a king ranch F450 that had one owner and exceptional maintenance. It is, however a earlier build 2011, 8/13/10. should I skip this one? I have read of dropping glow plugs and valves on the earlier ones. And some problems with the HVAC? It does have 126,000 miles on it, if it lasted that long could it be one of the good ones? I am looking at $35,000 and under and can not find ANY privet party Duallys in my area. I know the day after I buy one off a lot There will be one for sale just like it for $5,000 less privet party.
Thanks again, and I am trying to do a search on all my questions, and have learned a lot already, but it not easy to find ALL the answers.
I owned a 08/10 build 6.7. traded in at 130 k still running strong.. I've seen guys here posting heavy use commerical 6.7's of early years over 200,000 on them no issues.
Maintain it..use a fuel additive Ford makes... and you should be good.. I had turbo replaced at 105k... which they have changed design since then..and AC evap at 70k... that's it.
I have found 8 2011 that meet my needs. The one has good maintenance records. I have only found 3 2012, one is too beat up, the other to are about $10,000 more that the 2011s.
Then there is the question what would be more reliable, a well maintained 2011 or a abused 2012? I will need a truck with en the next two weeks so I can't be too picky
I don't think good maintenance or poor maintenance has anything to do with the 2011 valve issue. It's possible that the 2011s are cheaper and more available because some buyers, like yourself, are educated on the possible problem. Accepting additional risk means you get a lower price. This issue is one thing that makes the 2012 and beyond more valuable to the educated buyer.
You are fortunate that you're an educated potential 2011 owner. Plenty of threads here of unsuspecting buyers having the catastrophic experience shortly after taking ownership and Ford offering no help.
Bruce...
Bruce...
Thanks again for the responses! I am going to look at a 2012 tomorrow at a dealer and see if I can get the price down . King Ranch f450 with most of the options I want, but the carfax showes it is out of Alberta so I will need to look at idle hours. Anyone know if they salt the roads up there?
Wasted time at the dealer. I drive two hours and the 2012 f450 king ranch morphed into a 2011 lariat with rust issues. I told the salesman I came to look at the 2012 KR, his response was "close enough". I left NOT happy
The choices I have is another 6.0, but after looking at the newer trucks the 05-07 just don't look that nice any more, my wife even feels the same way. I can go with a 6.4, lots of them in my budget, but heard some really bad things about them. Or, buy the 2011 and gamble. I thing my odds are better with the well maintained 2011 than a 6.4. So I will go look at it tomorrow.
I have a 2011 and overall have been pleased with it. But, mine is a Job 2 truck, which includes chassis and engine upgrades.
Because of the issues with the early Job 1 trucks I would never consider a used one.
There have been a few 2012 models with turbo issues, but I don't know what is different with the turbos from 2011-2013.
I found a link to the TSB here: http://www.powerstroke.org/forum/general-6-7-discussion/420657-engines-breaking-valves-information-ford.html#/topics/420657?_k=jic0l5
6.7 DIESEL – RUNS ROUGH – NO CRANK – GLOW PLUG CIRCUIT DIAGNOSTIC TROUBLE CODES (DTCS) – BUILT ON OR BEFORE 3/29/2011
TECHNICAL SERVICE BULLETIN
Reference Number(s): 12-11-11 Date of Issue: November 16 2012
FORD: 2011 F-Super Duty
ISSUE
Some F-Super Duty vehicles equipped with a 6.7L diesel engine and built on or before 3/29/2011 may exhibit a runs rough or no crank concern. DTCs P0671, P0672, P0673, P0674, P0675, P0676, P0677, and/or P0678 may be stored in the Powertrain Control Module (PCM). The glow plug circuit DTCs may also be accompanied by cylinder misfire DTCs, cylinder contribution DTCs or other engine performance DTCs.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Does the vehicle exhibit a runs rough, no crank concern with any of the following DTCs P0671, P0672, P0673, P0674, P0675, P0676, P0677, and/or P0678?
a. No – this article does not apply. Refer to Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnosis.
b. Yes – proceed to Step2.
2. Remove and inspect the glow plug associated with glow plug circuit DTC present. Refer to Workshop Manual (WSM), Section 303-07C. Is the glow plug damaged?
a. No – this article does not apply. Refer to the PC/ED manual for normal diagnosis.
b. Yes – replace the engine long block. Refer to WSM, Section 303-01C.
i. For prior approval warranty repairs, complete cost cap tool by selecting short block, both cylinder heads, oil cooler and 16 lifters.
PARTS INFORMATION
Part Number Part Name
BC3Z-6006-F Long block
BC3Z-6079-B Installation Kit
WARRANTY INFORMATION
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB.
IMPORTANT: Warranty/ESP coverage limits are determined by the identified casual part and verified using the OASIS part coverage tool.
Operation Description Time
121111A 2011 F-Super Duty 6.7 L Check DTCs, Inspect 18.0 Hrs.
Glow Plug, Replace Long Block (Can Be Claimed
With Operation B)
121111B Additional time to contact hotline and complete 0.3 Hr.
Online forms. This operation is to be used only for
Dealerships that require prior approval (Can Be
Claimed With Operation A)
DEALER CODING
Basic Part No. Condition Code
6505 01
ISSUE
ACTION
SERVICE PROCEDURE
PARTS INFORMATION
With Operation B)
DEALER CODING
6505 01
I believe that tsb is for the bad glow plugs that the tips would fall off and kill the engine. Right or wrong I now own a 2011 F450 with 125 000 miles. I figured if it made 125,000 it probably one of the good ones , or, it has been repaired. I hope to find out more soon.
