Fender Support Bracket Needed
Old 10-11-2016, 07:30 PM
1964FORDTUF's Avatar
1964FORDTUF
1964FORDTUF is offline
Hi all -
Desperately looking for a fender support bracket - firewall to inner fender. Used, new, aftermarket (not angel iron I can make one of those!).
Pic below. Any leads appreciated.
Old 10-11-2016, 08:01 PM
ihcc104's Avatar
ihcc104
ihcc104 is offline
I got a bucket of parts from a guy down the road from his 60's Ford Truck... think I saw one in there. I will check tomorrow... if it's in there you can have it for whatever shipping costs. Ill let you know!
Old 10-12-2016, 12:11 AM
1964FORDTUF
Thanks that would be great since we are not too far away. You can PM me if you find it. Thank again!
Old 10-12-2016, 12:22 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 1964FORDTUF
Hi all -
Which bracket is it?
Old 10-12-2016, 12:46 PM
ihcc104's Avatar
ihcc104
ihcc104 is offline
Well for the life of me I cannot point them out on that picture. They mount to the firewall and allow the rear of the fender/inner fender to be connected to the cab... not sure they are on that pic.
Old 10-12-2016, 01:01 PM
TA455HO's Avatar
TA455HO
TA455HO is online now
I just dropped those 2 brackets and my inner fenders (aprons) off at the powder coat shop this morning.
The brackets are in that picture, just a little hard to make out since they are in a shaded area of the fender.
Front Fender To Cowl Side Bracket
C1TZ-16A165-B
Old 10-12-2016, 02:07 PM
NumberDummy
C1TZ-16A165-B (replaced C1TB-16A165-A & C1TB-16A165-B)
No Ford dealer or obsolete parts vendor has C1TZ-16A165-B or C1TB-16A165-A
C1TB-16A165-B =
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
Old 10-12-2016, 05:42 PM
ihcc104's Avatar
ihcc104
ihcc104 is offline
Well, just finished checking the stuff I was given and no brackets in there. Good luck on your search!
Old 10-12-2016, 06:41 PM
daveengelson's Avatar
daveengelson
daveengelson is offline
Do not know if the 64 fender supports are same/similar to the 65? These ole eye's find it difficult to determine by the pictures, but seem to recall seeing support brackets similar to the item in the picture? I have parts stored in box of 'stuff', it may take a day do go thru, if same will post pic's., cost of shipping only.
If understand correctly, Ford online part supplier possibly has 1 available; as ND would suggest, ' do not want to get caught snoozing'.
Old 10-12-2016, 09:17 PM
1964FORDTUF
Hi all, thanks very much and yes it is the bracket that bolts to firewall / cowl and supports / bolts to the the inner fender. I will call Carpenters and see if it is in stock for certain, will post again to advise.
Old 10-13-2016, 09:24 AM
1964FORDTUF
Called Carpenters. They are checking since only 1 shown in stock. In the meantime, my hunt continues for that and also for below circled strips of rubber that attach to back of inner fender. Ive circled the first item C1TB-16A165-B for reference and also the rubber strips now seeking. Any leads appreciated.
Eric
Old 10-13-2016, 10:22 AM
TA455HO's Avatar
TA455HO
Both of my 66 4WD trucks still have the original rubber strips attached. I don't know of a source for Ford replacements of those, but I did want to say that in all cases that I know of - the rubber strips go on top of the apron, not from the backside.
Old 10-13-2016, 11:39 AM
NumberDummy
Black star in front of basic part number refers to two different things. (1) Obsolete; (2) Not Serviced-Improvise.
In this case, it's Not Serviced-Improvise...since there's no basic part number of 16B126 listed in the truck parts catalogs (1957/63 & 1964/72) for any 1961/66 trucks.
Old 10-13-2016, 11:59 AM
daveengelson
Still unable to determine from photo in post #1 whether anything like the item U are looking for? Posting pic's, unfortunately I do not have a clue what part of the truck I salvaged the item from, or even if it's a bracket, or if there's a right and/or left?
Old 10-13-2016, 12:22 PM
1964FORDTUF
I talked to Carpenter. Im going to fab one after all. $15.00 plus 9.99 minimum charge to ship, I have plenty of steel laying around. Thanks all
Quick Reply: Fender Support Bracket Needed
