2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
New Dana axles
Old 09-20-2016, 06:05 PM
gbkeith's Avatar
gbkeith
gbkeith is offline
New Dana axles
Does anybody know anything about the Dane 275 and Dana 300 axles? Do the 275 trucks use bigger u joints and drive shafts than the 10.5 trucks? Are they actual new axles or just new names for say Dana 80's or 110's?
Old 09-21-2016, 06:27 AM
System's Avatar
System
System is offline
Prolocutor
Received 1,194 Likes on 573 Posts
There is very little out there on the net about them. They are entirely new but the odd thing is they came out a few years back, have not been implemented anywhere that I can see until now, and their key advertising point based on the one info release I found is improved fuel mileage. This is due to the way the gears mesh and the size of the mating surfaces. Nothing in the press release I found mention increased strength but maybe that's supposed to be implied.
Old 09-21-2016, 07:53 AM
Rasty1's Avatar
Rasty1
Rasty1 is offline
I heard the ford engineer talking about some of the weight savings they put back into the truck was bigger ring and pinion in these axles, also to get the weight and tow ratings.
Old 09-21-2016, 07:57 AM
System's Avatar
System
System is offline
Prolocutor
Well, if they caused the new GAWR on the SRW's, they can have them back.
Old 09-21-2016, 09:08 AM
Rasalas's Avatar
Rasalas
Rasalas is offline
The SRW F250 still retains the Sterling axle used in the past.
The SRW F350 uses the Dana M275 with an axle diameter of 1.47"
The DRW F350 uses a Dana M300 with an axle diameter of 1.47"
The DRW 450 uses a Dana M300 with an axle diameter of 1.85.
These axles are heavier duty overall and use fewer moving parts and are more fuel efficient than the previous Sterling Axles.
Old 09-21-2016, 09:10 AM
System's Avatar
System
System is offline
Prolocutor
One addition Rob, the 250 with HD tow pkg. has the M275 as well...
Old 09-21-2016, 09:28 AM
Rasalas's Avatar
Rasalas
Rasalas is offline
Yup!! Thanks, I forgot to include it.
Old 09-21-2016, 11:30 AM
17 Oaks's Avatar
17 Oaks
17 Oaks is offline
Wondering if this is it:
Spicer AdvanTEK High-Efficiency Axles | Dana Light Vehicle
AdvanTEK® Gearing
A Full Range of Quiet, Lightweight, and Reliable Drive Axles for
Light- and Light-Commercial Vehicle Applications
Pinion features to enhance reliability:
Larger diameter pinion stem
Narrow pinion bearing spread
Two-stage pinion preload setting
Pinion mate spherical torus shape
Pinion features that reduce vibration:
Pinion built to position rather than pattern
Major diameter pinion spline fit
Reduced pinion nut backface runout
Gearing features to improve durability:
Wider drive gear face
Differential gear tooth combination
Large diameter flange side differential bearing
Gearing features that maximize efficiency:
Fuel efficient taper roller bearing
Smaller button side differential bearing
Thrust washer features for a quieter ride:
Dynamic backlash measurement
Belleville side gear thrust washers
Thrust washer lubrication holes
Old 09-21-2016, 11:43 AM
rocket_scientist's Avatar
rocket_scientist
rocket_scientist is offline
17 Oaks's link has a picture of something that looks exactly what I saw in a recent video of under the truck footage (guy drove over the camera.) The driveshaft was turning and connected to that exact thing in the back. So he may be on to something. Same shape, same fins. The video was posted here but I don't remember which one.
Old 09-21-2016, 02:10 PM
wheelerfreak's Avatar
wheelerfreak
wheelerfreak is offline
So it has a slightly larger ring gear diameter by about .3" and a smaller axle shaft diameter that the 10.5 Sterling which is 1.5"? I wonder what the tube diameter and thickness is?
Old 09-21-2016, 08:22 PM
gbkeith's Avatar
gbkeith
gbkeith is offline
It has larger axle shafts than the 10.5. The 275 shafts are 36 splined, 1.43 Minor spline diameter and 1.54 major. The Sterling has 35 splines and is 1.36 minor and 1.50 major. The 10.5 has 3.5 inch tubes while the 275 has 4 inch tubes. Sterling holds 7 quarts of lube while the Dana holds 7.2
Old 09-21-2016, 10:18 PM
Marching Ant's Avatar
Marching Ant
Marching Ant is offline
Which one is rated at 7230lbs?
Old 12-04-2016, 05:36 PM
sdunham's Avatar
sdunham
sdunham is offline
I've been trying to track down some info on the Dana M275 which will apparently come under the rear of a '17 F350 4x4 CC KR I'm configuring for order soon... Do you know if/when 4.10's will be available for this axle and if/when ARB will offer an Air Locker for it by any chance...? I can't find any info on this axle on the Dana nor ARB websites...
Old 12-04-2016, 05:57 PM
17 Oaks's Avatar
17 Oaks
17 Oaks is offline
These folks will prob know long before it hits the news items.
https://www.dynatrac.com
I know the owner Jim, he mods Ford Dana's and does a lot of custom work for Ford and Chrysler, they know more about Dana than Dana does...Most likely its a bit early for any announcements as it takes a while to build the new gear and before that happens there has to be at least a perceived sales opportunity.
Old 12-04-2016, 08:32 PM
gbkeith's Avatar
gbkeith
gbkeith is offline
I'd bet money Dana has made 4.10's for it at some point during development. It's been out for a couple years and Dana has surely been shopping it to manufacturers. 4.10 is too commonly used not to have made one. Wouldn't hold my breath on the ARB anytime soon since an electronic locker is already available for 3.33 and 3.55. Don't know where the carrier break is but I bet they made one for 4.10 too.
Quick Reply: New Dana axles
