1948 Ford F1 - Inner Oil Seal - front bearing ?
Does the inner oil seal have to be pressed in tight against the bearing? If not what limits the movement of the bearing slightly? I have just got it to sit flush, but it seems as though that would allow the bearing to still move in and out of that bearing race slightly?
You have the seal correctly installed, it should be flush with the hub. The seal runs on the shoulder, the inner race of the bearing fits against the shoulder. When you adjust the bearings you are tightening the bearings between the shoulder and the nut. It is normal to have the space between the bearing and the seal, so that the seal is running on the shoulder and not on the edge of it.
Mark
Mark
The text section of the catalog is required to get the complete part number by adding the prefix and suffix to the basic part number.
This is the Ford part number, I don't have access to auto parts store part numbers (Edit: See post 7):
01Y-1190-A .. Front Wheel Grease Seal - 2 3/4" O.D. / Obsolete
1948/52 F1/F2/F3 / 1953/56 F100/250.
SOEBY MOTOR CO. in Walhalla ND has 2 = 701=549-3711.
COLLECTORS AUTO SUPPLY in Oroville WA shows 4 (800-414-4462), but I'd be surprised if they actually have them in stock.
BOWMAN SALES & SERVICE in Bowman ND has 5 = 701-523-3257.
FRIESEN FORD in Aurora NE has 6 = 402-694-3111.
Ok, so I thought I was past this also. if I set the seal a bit beyond flush in ward, would it not allow the bearings to seat properly. I get the whole assembly on, washer and nut and tighten down, back off a fuzz and the hole wont aline for the cotter pin, can get about half the pin in sooooo?? options, solutions? figured I would ask before I go with standard and yard on it to make it work.
It will not stop the bearing from seating against the shoulder of the spindle.
The seal may rub against the inner bearing if it is pushed in too far.
You should assemble with washer and nut, spin the wheel in the normal direction as you slowly tighten the nut. If you feel any roughness to the rotation, then you have a problem with either one of the bearings or the seal is rubbing against the inner bearing.
...Terry
As you slowly tighten the nut, it will be obviously when it is too tight, the wheel will be hard to rotate. Then you would loosen the nut until the cotter pin will fit in, test by spinning the wheel. Keep loosening the nut, one opening at a time until the wheel spins ok and the cotter pin fits in ok.
When you think it is close, spinning ok both directions, grab the top and bottom of the wheel and pull and push to see if you can feel too much free-play.
...Terry
Its so close, It spins fine, I can see daylight thru the cotter hole, Both sides same thing, I just didn't want to crank it down and destroy the bearing.
It seems like outside bearing is not seating completely in race, granted were talking less than an 8th.
Or maybe Im just been too careful. Ive got a #12 cresent and cranked on it.
If you cannot get the cotter pin thru the nut and hole in the spindle there could be a couple of reasons.
You can see thru the hole and nut slot? But not enough room for the cotter pin?
-If the nut will not turn in enough for the cotter pin to get thru, one of the cones may not be pressed far enough into the hub.
-Or you have a wrong part (bearing race, cone, washer, nut?)
-Sorry to ask....wrong size cotter pin?
...Terry
...Terry
78longbed
11-10-2008 09:24 AM
cgillispn
06-08-2004 05:39 PM
bremen242
10-01-2003 09:38 AM
