1998 conversion van Key fob programming and looking for the connector
Tried programming a new key fob. System won't go into programming mode(doors lock unlock). So I found the module behind the driver side yet there is no extra connector to jump the pin to put it into programming mode. I also looked underneath where the steering column is. Still no luck. It's a 1998 conversion van e150.
Any ideas where the connector is or why it won,t go into programming mode as described in the owners manual? All my other fords work as advertised.
COLOR of wires into connector?
i found 1 black unused connector. it has a BLACK wire and a WHITE W YELLOW STRIPE WIRE going into the connector . is that the what i'm looking for?
most posts describe it as white w yellow stripe and a grey w yellow stripe wire. ill check it later and confirm
racefan966
09-30-2023 04:59 PM
darmst
09-28-2022 07:18 PM
PRIMERED79 SHORT BED
12-29-2018 08:40 PM
rjfetz1
1999 to 2016 Super Duty
13
04-08-2009 04:50 PM
