Trailer Lights Issues!!!
Please help me before I loose my freaking mind. I worked on this for no shorter then 6 hrs. Still giving me issues. I have no running lights on the trailer. It keeps popping the fuse under the hood. I installed new 7 pin connectors(male and female. Traced the wires back. Checked the truck plug for power and ground, checked for continuity in the trailer whip wires, got underneath and found a melted mess where the trailer whip connects to everything else. Cut all that out and started fresh. I am at a total loss. I have trailer brake lights and turnsignals but every time I turn the running lights on the fuse pops. I have looked for bare wires, etc. The only strange things I have found is that with a test light on the truck side the turn signals will light up when probed with positive and negative.
Any wiring experts here . It's a MSI cargo trailer.
Please help I am pissed off an lost. Not a good place to be
So, I think the markers are fed by the green lead. If you disconnect the lead for the markers at the J box, you can plug in and turn on the markers and the fuse doesn't blow, correct? If it blows the fuse, your trouble is ahead of the J box.
If the fuse holds, can you tell how the feed runs for the markers? If you can, you can work along the lead one light or maybe several lights until you reach the point where the fuse blows. For example, disconnect after the first light. Now power up, did the fuse blow? If not the short is after the first light. If it blows, it is between the J box and the light and so on. Also don't forget to check the connection for each light at the light itself.
When I have to trace stuff like this, I always take it one step at a time.
Steve
Steve
They take a 1157 bulb. They are the original lights. Trailer is an 2001. These are the lights I have.
Bargman Recessed, Double Tail Light - 84 Series - Red - Black Base Bargman Trailer Lights 30-84-527
Since the short can be anywhere including the socket or connections to the lights, if you get lucky, it will be in a bulb. Rather than go a bulb or two at a time, to determine if the problem is any bulb, if they all are removed and the fuse still blows, it is not a bulb.
Steve
Steve
Makes perfect sense.
Okay. I am not trying to be dumb here. But what is the j box? Is that here the trailer pigtail meets the trailer wiring? With the trailer pigtail unplugged it does not trip the fuse, As soon as I plug the trailer in it pops.
EDIT, I am sorry. It took me a min. Okay. I can dis connect that and try it out.
