Duallys Only
Duallys Only
Following my own advice I am going to start this thread because duallys are getting popular for whatever reason. So post your dually pics, mods you have done already and mods on your to do list.
Here is mine:
http://cimg0.ibsrv.net/gimg/www.ford...e7a95b2b55.jpg
2014 F350 Lariat crew cab chrome pkg. Loaded with tools weighs in at 11,100lbs. I have installed stable loads to raise up the back end, Bilstein shocks. I need to install my 12v compressor and air horns. I also plan on a Flo-pro exhaust system with delete and SCT X4 tuner in the spring.
Here is mine:
Top Answer
09-09-2022, 08:37 AM
pics will come a little later, Mine is a 2012.. Rancho 9000xl adjustable shocks, with wireless controller.
Firestone airbags 2535 kit, with Airlift Wireless One controller.
these came off my 2012 F250 SRW, SB. trade for the dually.
Viair 10007 on board air kit. Upfitter 1
recently added an LED light bar to the front, wired to Upfitter 3 and brights.
60 gal RDS toolbox tank, gravity feed, with electric cutoff, wired to Upfitter 2.
Use a B&W Patriot 16k rail based hitch for the FW, as the rails were already installed when I purchased the truck used with 6000 miles, August 2013.
also have a Tuff Tonneau soft roll up bed cover
Locking gas cap, just today added a lock to the fuel door itself.
This is a lariat with sunroof and nav. The hood was open cause I was looking for the pins that hold the cowl to the gasket.. the PO had the shroud wrapped, but they didn't secure it again. dealer didn't have the pins like they said they did!
Received 3,997 Likes
on
Jolly Green.....
2015 F-350 Built 07 November 2014....King Ranch DRW....14,000 lb Gross Weight.
Current Modifications:
Tough Country Bumper/Moose Guard, Powder Coated to Match the KR Accent color - Caribou Metallic
Smoked lenses on the Cab Clearance lights.....Fender Clearance lights.....Mirror Clearance/signal lights
DuraFlap Mud flaps.....14" Front and 20" Rear
Spray on Bed Liner
DieselSite Aux Fuel Filter/Water Sperator
B&W puck system 20K 5th wheel hitch
Ford under bed Goose Neck Ball
Access Limited Edition Tonneau Cover
SS Braided air line extension on the duallys
Work continues.......Link in my Signature......to the on going build and photos
Very Top of screen............
B&W 20K Hitch.....puck system
This was uninstalled from the 2011 F-350....and Installed on Jolly Green. DieselSite Filter/seperator.
Chrome 3D Letters...... Note: 4X4 Sticker has been removed
Gold decals in the SD recess .........Dealership Sticker removed
Spray on Bed Liner
on
Roy
