1967 F250 restored roller or motor included
Year: 1967
Make: Ford
Model: F-250
Price: $5000
Mileage: 0
Color: blue
Private or Dealer Listing: Private Listing
Location (State): CA
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Color: Blue
Engine: 460 bored to 501
I will separate, 6800 for motor and trans (Built C6)
5000 for truck roller, OR 10K for package
TRUCK INFO
This was a frame off restoration started and will not be finished.
The frame was taken off sandblasted and painted with chassis paint.
The underside was completely restored and painted (Underside of cab and bed)
The rear end was rebuilt, it is a DANA with 373 gears. There are stainless steel brake lines installed on rear end.
All brakes are brand new, including completely rebuilt front disc brakes.
The inner fender wells have been powder coated.
The interior is newly painted to match the exterior. Restored (painted/dent free) door panels.
The dash gauge cluster has been restored and all gauges are rebuilt
The grill has been restored and polished
The headlight surrounds are brand new from Dennis Carpenter
New in the box rubber floor mat
the interior floor has been professionally coated in bed-liner type material
All windows are installed and have brand new rubber
Brand new steering box not bolted to frame
MOTOR
Motor is a Ford 460 bored and stroked to 501 cubic inches, with Headman headers
BUILT C6 Trans with 2k stall
Bore is .30
Stroke is 4.14
Complete set of March Polished Pulleys Included
Dove heads with 77cc combustion chamber
Recess JSE pistons
4340 Forged H Beam rods
Street Strip ring set, rod bearings,main bearings
Eagle cast Stroker Crank
Weiand Intake
Holley 770 Carb
Ford Racing Valve covers
MSD billet distributor, MSD 6AL BOX, MSD blaster coil, MSD lean rich reader (Bung already in header tube)
Holley fuel pump and Holley fuel pump with wiring and switch
FOrd Racing 9 mm plugs
New Spark Plugs
New high output Alternator (Black powder coated)
Chrome Ford Racing Dipstick
I am sure there is more i am not remembering....
Come and look at this package if you have a bit more money and a bit of elbow grease you can have a beautiful
frame off restored truck
I HAVE MORE PICS IF YOU WANT JUST CALL OR TEXT
NO new wiring (Old wiring in box), no Steering Column (do have new steering box), no radiator, and no brake master, most everything else is there
MY LOSS your gain
Give me a call 951-750-9383
Riverside Ca
Ryan
BLstangin
11-12-2016 09:43 AM
