1978 - 1996 Big Bronco
What did you do to the Bronco Today?
Old 08-22-2012, 10:13 PM
bigzirb's Avatar
bigzirb
bigzirb is offline
I searched all over but couldn't find a thread like this on the Bronco side. If there is one that I didn't find just have one of the mods delete this one please.
With all that said, post up here and let us know what you did to, or with, your Bronco today. Anything from completing an axle swap to starting it to move it over in the driveway. There are lots of build threads to keep up with so feel free to keep it a short update here as a reminder for the rest of us to check your build thread for the complete update.
Today I started cleaning off the firewall to weld some reinforcement plate on due to my hydraulic clutch conversion. No pics yet as the camera is acting up but I will post them.
Let the fun begin.
Old 08-23-2012, 08:17 AM
Edgethis's Avatar
Edgethis
Edgethis is offline
I cleaned up the engine bay, getting ready to replace the header gasket. Had to order some nice copper gaskets, hopefully they last.
Old 08-23-2012, 08:30 AM
the truth's Avatar
the truth
the truth is offline
Haha. Have to have pics.
Old 08-23-2012, 10:34 PM
bigzirb's Avatar
bigzirb
bigzirb is offline
I cleaned up the firewall to prep it to weld in some reinforcing metal. I was only cleaning around the holes and the perimeter where I will be welding so the rest is still covered to help prevent rust issues.
Tomorrow starts the welding.
Old 08-24-2012, 09:33 AM
Boss351Bronco88's Avatar
Boss351Bronco88
Boss351Bronco88 is offline
I stare at it in the garage, waiting in anticipation for the motor. Pick it up the 31st. Dropping it in that weekend and coming out the garage tires blazing.
Old 08-24-2012, 10:53 AM
cje07's Avatar
cje07
cje07 is offline
Too funny boss...guys its been along time since I have been on the site! My Bronco has been parked in the stall for the last 2 years. If any of you recall I did a full body resto complete with bedlining on the whole thing!
I had to park it because of other mechanical work that needed to be done...needless to say I run or ride my bike to work over the last 2 years...now, its time to bring it back out. Gotta do an oil change, new oil pan, TPS change, steering gear gasket...blah, blah. You'll see me more active in the coming months.
Anyway...I just stared at it and day dreamed... safari rack to come too!
Old 08-24-2012, 11:46 AM
bigzirb's Avatar
bigzirb
bigzirb is offline
I started welding on the firewall, figured I would post a pic on the lunch break. I also need to let it cool before I continue tack welding it in place.
Keep up the work guys!
Old 08-24-2012, 01:16 PM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
I repaired my rear window motor by opening it up, cleaning out the crunched up bits of plastic, and replacing the bushings with 1/4" nuts. Works better than ever.
Old 08-24-2012, 02:37 PM
Southern Bronco's Avatar
Southern Bronco
Southern Bronco is offline
Replace my ignition coil w/ a MSD, cleaned the throttle body, and replaced the IAC valve. Also replaced a couple of missing screws in the D/S door panel
Old 08-25-2012, 12:29 AM
ford1977owner's Avatar
ford1977owner
ford1977owner is offline
today i got a wire wheel, got rid of the rust on my back rear, and leaf springs, paint them black along with some other things underneath, getting read to paint the frame, shackles, front springs all yellow
Old 08-25-2012, 09:52 PM
justgunner's Avatar
justgunner
justgunner is offline
installed a new stereo w/dvd,.and some speakers,.weird that,.there is a wire they want you to hook to your parking brake light, so you wont watch dvd's while driving,.,LOL I grounded it and it works just fine while driving, LOL (mobile ****),.but really i'm getting a dvd monitor for the back for camping and such,.it works good and for a 3.5" screen its really clear,.
Old 08-25-2012, 11:01 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
Hello hello. Today, i did half of a hub rebuild on TGM. I had 2 broken studs so now i got all 5 new ones along with a brake rotor and bearings. Tomorrow will be the driver side. I would drop some pics but i just posted 27 of them here..
https://www.ford-trucks.com/forums/1...ct-tgm-13.html
It was my first time doing hubs. not as bad as i thought.
Old 08-26-2012, 10:03 AM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Abandoned, is it more noisy now?.
Well, I went to the window and watched the Bronco, she looks nice all cleaned up. It hasn't been that clean in months.
Old 08-26-2012, 12:09 PM
AbandonedBronco
Not at all, the nuts don't rotate, they're just internal bracing for the motor to gear. Nice cheap fix and stronger than original!
Old 08-26-2012, 12:49 PM
Encho's Avatar
Encho
Encho is offline
I know, I have it on my truck, but I was told so and since I can't remember, I ask.
Quick Reply: What did you do to the Bronco Today?
