Plate in front of rear shock??
Here is the installation procedure: Hellwig rear antiswaybar He doesn't say anything about the plate, but also doesn't show in pictures. Hope that helps.
on
I knew I would be wrong sooner or later. The spindly little cable bracket could have mounted on the shock bracket so that's not it either so I am going to go back to protection again but this time from the heat coming straight back from the cat and muffler which was probably ruining the shock mount or heating up the banjo. You are right about the other side so it's not protection from rocks etc. There is a ton of heat coming straight back due to the convection principle.
<br />
So you mean I'm not missing one? It looks so odd I thought for sure there was one missing on the other side for some reason. Just hadn't gotten around to posting to ask what it was and where to find one yet.
on
I just always thought I was missing one. I have the same setup you guys describe. The exhaust explanation seems most logical. I guess it would make mine useless now since the exhaust pipe is up 8" over stock. I've been thinking about ladder bars for when I get really big wheels and lower gears... so maybe I have that stupid plate taken off at that point.
on
I looked at a Hellwig site and it shows install pictures with this guard. They have a bracket mounted to it and three bolts. Mine only has two bolts and unless I do some modification to it, the included bracket will not fit. The top of the plate is the issue. It is missing a hole and the angle of the guard faces forward at about 45*. Just wondering if anyone has installed a Hellwig with this plate there and we'd there any issues.
