Ford F100 4x4 - Factory 292
Year: 1959
Make: Ford
Model: F-100
Price: $2100
Mileage: 99999
Color: Academy Blue
Private or Dealer Listing: Private Listing
Location (State): MO
Transmission: Manual
Drivetrain: 4WD & AWD
Color: Blue
Engine: 292 Y Block
Pictures available at 1959 Ford F100 4x4 - Factory 292
This Academy Blue F100 rolled off the Kansas City assembly line on - August 04, 1959. From everything I have been able to find this looks to be factory 4x4 gear and not a M-H or Napco conversion. This isn't a truck where somebody stuck a 1970's 4x4 set of running gear in it or tried to transplant the body onto a late model truck. The VIN plate in the glove box shows it coming with a 292 Y block which is what is under the hood.
This truck comes with the flatbed installed as pictured. The Styleside bed is the one pictured sitting under the tree. I put a bed from my other truck on this one to take a picture. The styleside bed included is the one shown NOT mounted on the truck.
-The engine is a 292 Y-Block. If you aren't familiar with these engines you can read the success Karol Miller had building them up and racing Bonneville back in the late 50's. Y-block Ford powered T-bucket: Ford Success Stories: Karol Miller ... Bonneville Legend
-3 speed column mount transmission "Three on the Tree"
-Axles - Dana 44 closed knuckle on the front with a ford 9" in the rear
-Overall the front end cab interior and exterior are in good shape regarding dents and trueness. Some patches needed at the base of the fenders and lower portion of the door skin needs some work. LMC truck and similar websites carry patch panels and other parts for a restoration.
-Both doors and the rear glass is in good condition. The front windshield is cracked and needs replaced. It isn't leaking. A local shop quoted me $185 for the glass.
-Wheels and tires - turbine style as pictured. No spare included
-The frame has normal surface rust but is solid
Buyer is responsible for any shipping costs and arrangements. We will help load it on the buyers transport.
I bought this truck after it had sat in a barn for the last several years. When we cranked the engine it turned over but didn't fire up. We went ahead and pulled it apart to check everything out, overhaul as necessary, then go from there. The only issue we found was one of the push rods was slightly bent and a mouse had tried to move into the exhaust system. Right now the engine is disassembled so you can decide if you want to put in a new rod, replace the gaskets and drive it as is or to do any other changes while it is disassembled. The main bearings and other components don't show a significant amount of wear.
Any questions please call 424 two three four 6634
darryl dayton
68
02-21-2012 06:39 PM
1959f14x4
02-26-2007 05:38 PM
