Which Studs?
Which Studs?
okay so im outta luck i gotta find these studs and fast i tried every parts store and hardware no one has the studs in grade 8 at least. kinda stupid if you ask me.
but never the less i was wondering if these would work?
Dorman Products - 329145
Google: Hillco Fastener Warehouse,inc. I think you can buy online and have shipped.
Tel: 714 657-7442
You need 14 of each of these: AV09686 3/8-1 SAE 3/8-5/8 USS X 2 overall *(I like to use the 2 1/8" studs if they have them.
9SAE500HD 1/2 SAE Heavy Duty Flat Washer
8SAE310 5/16 SAE Flat Washer Grade 8 Yellow Zinc
838024GC 3/8-24 Grade C Locknut
Coat the coarse threads with anti sieze compound. Get two 3/8 X 24 nuts, screw them on the fine thread end and torque a bit against each other. Then insert into head and tighten with open end wrench 20 lbs torque, approx. Put an open end wrench on each nut, and remove nuts. Repeat 14 x.
Use Mr. Gasket #260 int/exh gasket.
Tel: 714 657-7442
Tel: 714 657-7442
Tel: 714 657-7442
These guys have a little more user friendly site:
3/8-1 Sae 3/8-5/8 Uss X 2 Overall
This (I think) is what we need: (Please correct me if I'm wrong, here)
Yes, the 1/2" washers will be loose on the 3/8" stud. That is so you can move it a tad to grab the 'ear' of the intake and the flange of the header. Also, there is a smaller washer over the top of the 1/2" one to firmly hold it in place.
The problem is this: The header flange and the intake flange (ear) that the washer tightens against are different thicknesses, so when you tighten the washers they sit crooked. The way I solved the problem was to take the original thick washers, clamp each one with a pair of vise grips, and grind off 1/16" off one side of the washer. That now thinner side of the washer is placed over the thicker flange to compensate so the washer tightens straight and torques evenly. If you go this route, then don't order the washers.
*If you go to junkyard to get the oem thick washers, don't take the efi year ones. They are impossible to remove from the bolts. Good luck.
