Pre heater parts needed 68 6 cyl 300 engine
been looking for months for parts for 68 f100 6 cyl 300 engine. i need the pre heater assembly. the parts are 9a626, 9a603, 9c670, 9652. those being the lower mounting bracket, lower hose attachment box, the hose itself, and the snorkle that goes onto the air cleaner.
some please point me in the right direction. please dont guess where to go, ive done enough of that.
Which air cleaner does your truck have...dry type-uses a paper filter or an oil bath air cleaner? Both were available in these trucks, the parts do not interchange.
Basic Ford part numbers require a prefix and suffix to make up a complete part number. I will look up, list and search for them...to see if anyone has NOS parts...as soon as you post which air cleaner your truck has.
EDIT: See post # 5.
Applications: 1968 F100/350 240/300 / 1969 F100/350 240/300 before serial number D96,001 // 1968 Galaxie/LTD 240 / 1969 Galaxie/LTD 240 before 10/15/1968.
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
C8OZ-9A626-A .. Duct Assy / Use with Dry Type Air Cleaner / Obsolete
Applications: 1968 F100/350 240/300 / 1969 F100/350 240/300 before serial number D96,001 / 1968 Galaxie/LTD 240 / 1969 Galaxie/LTD 240 before 10/15/1968.
1968 Fairlane/Torino/Falcon/Mustang 200 I-6 / 1969 Fairlane/Torino/Falcon 200/250 I-6 before 10/15/1968 / 1968 Bronco 170/200 I-6 / 1969 Bronco 170/200 I-6 before 10/15/1968.
CARPENTER NOS OBSOLETE PARTS in Concord NC has ONE = 800-476-9653.
DICKERSON MOTOR CO. in York SC has ONE = 803-684-4225.
9C670 = There are TWO types, I need the last 6 digits of your trucks VIN / Will edit the info into this post.
C5TZ-9652-A .. Flex Tube between 9A603 & 9A626 / 3.02" I.D. / 20.76" long - Cut to 18.00" to fit your truck / Obsolete
Applications: 1968/69 F100/350 240/300 // 1965/69 N600 300 H/D // 1970/72 B600 300 H/D (B = School Bus).
At one time, NAPA carried this "universal" flex hose. Haven't bought any in several decades, so I dunno if they still have it or not.
NOS PARTS SOURCE in Olathe KS has ONE = 913-220-5746.
> > THE 1964/72 FORD TRUCK PARTS CATALOG is available on a CD from hipoparts.com for 20 bucks. The pic you posted from Fordification is from this same CD catalog = Illustration Section 96, page 12. < <
Parts catalog pics only have basic part numbers shown = You need the TEXT section of the catalog to get the complete part number.
Buy the above CD catalog, it includes the whole tamale! Text & Illustration Sections & Master Cross Reference Section at the end of the Text Section: Manufacturer part numbers to Ford part numbers & vice versa.
I have the CD, an original loose leaf paper version, an original microfiche version.
Need the same parts for an 69 F100 after D96,001
I am looking for the same shroud and tube (I think it is also called a heat riser) for a 69 Ford F100, 240, SN E90398, dry filter, so it is after the SN provided below. I have the CD referred to, but can seem to figure it out.
Anyway, could you help me identify the appropriate parts and where I might find it? I don't need the snorkel, just these (9a603, 9c670, 9652). Appreciate any assistance.
C9ZZ9A603E,replaced by D3DZ9A603A, replaced by D3DZ9A603B, replaced by D9TZ9A603A.
D3AZ9C670B
C9UZ9652A. This is a "Kraft Paper" cut to fit duct. Still available from Ford.
Green Sales
(800) 543-4959
Has the C9ZZ9A603E,D9TZ9A603A, and D3AZ9C670B.
1969 FROM SER #D96,001:
C9ZZ9A603E .. replaced by D3DZ9A603A, replaced by D3DZ9A603B, replaced by D9TZ9A603A
D3AZ9C670B
C9UZ9652A This is a "Kraft Paper" cut to fit duct. Still available from Ford.
Also available from auto parts stores
Green Sales (800) 543-4959 Has the C9ZZ9A603E .. D9TZ9A603A .. and D3AZ9C670B
D3AZ9C670B
Part doesn't match
So I ordered part D9TZ9A603A and the bracket from Green. The bracket is identical to the broken one I have, but the shroud/tube is definitely different. The angle where the bracket mounts is about 60 degrees off, the tube is longer and the shroud is very different. At this point, I can't tell if it will work. here are pics. The black one is the new one. Question is whether it will work? Thanks.
https://www.ford-trucks.com/forums/a...1&d=1484849440
I'm sure it will work. The part number you purchased is a Dentside part that Ford had used as a "replacement" for earlier models back in the day. The C9UZ9652A Kraft Paper duct is a pretty long cut to fit piece. From memory I want to say it is around 14". So it will be long enough to reach this shroud.
The C9UZ9652A Kraft Paper duct is a pretty long cut to fit piece. From memory I want to say it is around 14." So it will be long enough to reach this shroud.
