PLease HELP - F-150 won't go above 30 mph
Hello - My truck will not go above 30 mph - rpm's will rev high but, speed will not climb. I was able to put the truck in 2nd gear and drive home at @ 40 mph. Truck has 135K miles on it, I'm the original owner. If anyone has any ideas as to what this might be I would greatly appreciate any info before going the mechanic.
Don't waste time on a flush, A flush will never ever ever fixes anything. if it is the transmission flushing it will just waste money, take it to a trans shop to just let them drive it. also give a little more specifics, year, engine, etc. so will it not shift, does it shift from 1 to 2 when manually shifted?
I'll disagree with jt351...I've had several higher mileage vehicles come through the shop that would shudder and lag that a flush completely solved the problem. Flushing out old crud than can be clogging the ports and inlets for $80 is a lot better than the cost to drop a tranny and rebuild. It's a good first shot for cheap, always start with the easiest and least expensive fix first! A shop is going to charge at least an hour labor to start to diagnose an issue like this, at a minimum of $75 an hour.
If as you were driving your rpm's just kept rising but you were not going any faster, it sounds like a snap ring for your drive or over-drive gear. This would not allow for your transmission to shift into the next gear properly. Which in turn would not let you exceed the speed set for the transmission to shift. This is about a 1300-1600$ fix. Don't waste you time or money on a flush, but you could save a couple bucks and buy the gasket, fluid, and filter on your own instead of the shop charging you 21% over the sale price of these parts.
2006 Ford Expedition Ran out of gas
Hi
The other day my wife was driving the car and it ran out of gas. So I walked over to where she was at a filled a little less then a gal of gas in the tank and luckily we were in the neighborhood so i drove it home slowly. I went to get 6 more gals of gas, and it is running like crap. It has a rough idle and won't drive over 20mph. I've changed sparkplugs, fuel filter and both camshaft sensors. I have a codes now for camshaft P0345 P0349 and running lean and rich codes P2197 and P2198. I'm stuck and have no idea what to do. Any help would be appreciated.
Running any modern vehicle , with the pump in the tank , is bad news.
the pump is designed to be immersed in gas , when you run one out of gas ,
the armature in the pump is exposed , and gets very hot very quick , and can fry the pump , and/or the wiring attached to it .
might also check fuse .
