FS/FT 1980-96 F-Series Parts - Radiator, Exhaust, C6... (NJ)
Category: Accessories
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude, Fit, S2000, CL, TL & Vigor, Hybrids
Item Condition: NJ
Engine: Part suitable for gas truck, Part suitable for diesel truck
Copper/Brass radiator fits 1980-84 F100 / F150 / F250 / F350 or Bronco with 300 / 4.9L inline six, without A/C. Automatic transmission. Same as Spectra #CU557. Radiator is in good shape, nothing bent or broken on it, clean inside, straight fins, always kept my truck cool. Includes newer hoses (less then 3K old). - $40
Old style 240 / 300 / 4.9L Ford straight six valve cover, "Power By Ford", was media blasted and painted a little while ago - $15
1977-91 Ford F100 / F150 / F250 / F350 and Bronco hubcaps (2WD); could use cleaning but 4 of 5 are in nice driver condition - $20 /set
1981-86 F-Series & Bronco headlight bezels with amber parking lights; good for work trucks - $10
Custom welded exhaust system for regular cab short-bed 117" wheel-base trucks with the 4.9L / 300ci six; came off of my Flareside. Dual collector 2.25" y-pipe into 2.5" single, Magnaflow cat, stainless Gibson muffler and 3" inch Magnaflow tip exiting behind rear passenger tire. Was on the truck for ~5k. Truck was 2WD, but should fit 4x4 as well and could be easily extended for longer wheelbase truck. Was used with Hedman header, PN# 89300. Exhaust video here:
Starters: one off an 80's Ford truck with a 300 I6, one off of a 70's big block 429/460. Both tested and in working condition, both out of automatics. - $10 ea.
1990's Ford/Alcoa Classic 8 hole caps for 2WD rims, ~3.5" deep, decent condition - $50.00 or trade for 4.5" deeps
1980-86 RH Marker w/light, original FoMoCo take-off with nuts, in decent shape - $5
1987-96 Driver Door Parts - Best Offer
1980-86 Bronco Heater Controls w/ window switch, untested - $10
1980-86 Bronco in-dash A/C Unit (Evaporator, Valve, Blower Motor, Housing) - $50
1980-86 Grille upper and lower trim, three uppers, one lower. Top upper is in nice shape ($10), the other two uppers and the lower are ok but need to be shined up ($5 ea.). The other two trim pieces, I have no clue what they are, so best offer.
1980-86 F-Series & Bronco dash face with steel reinforcementd; no cracks, no holes drilled, paint worn in some places. Dash was pulled from Bronco with Dealer Installed A/C, comes with glove box light switch - $100
Many interior trim pieces, dash boards and dash parts, bench seat, bench seat frame, glove box doors, trim panels, windshield metal trim, dash wiring harnesses, steering columns (one out of an automatic that's worn/good for parts, and one manual truck column that's serviceable/restorable), Flareside bedsides (need work but fixable), tailgate, exterior chrome, vent windows, window regulators, taillights, western style mirrors, dash bezels, steel wheels, etc.
If I don't have it, I may know where to get it, so feel free to email for parts not listed.
Will take a trade on:
- 1980-84 F-Series & Bronco Rosewood horn pad
- Black seat belts for bench seat (need everything but the shoulder belts)
- 1970's 429/460 or 1983-85 Mustang 5.0 dual snorkel air cleaner
- 460 P/S pump and alternator brackets (V-Belt system)
- 1983-86 Diesel Tach setup, cluster or gauge, sensor and ribbon
- 10.25 Sterling Dually rear, with spring packs (prefer 3.55 posi)
- 1980-97 Ford Dually Bed w/ fenders, rust free, with or without tailgate
- Dana 60 w/ dually hubs (prefer 3.55s) w/ F350 Spring packs
- Gear Vendors setup for C6, 4x4
If you any of this stuff, definitely interested in working out a deal, or may buy outright.
Local pickup preferred (Northern NJ, zip 08833), will ship smaller stuff; PM me with any questions...
Thanks for looking!
I do not, however, if you are in the Philly area or within driving distance:
1984 FORD TRUCK TAILGATE BRAND NEW
Worth a shot. Thanks!
Thank you for looking that up!!! I thank that may be aftermarket but I will check it out. What I'm trying to find is the OEM with the FORD letters raised on the gate. After markets don't seem to be that way and everyone has told me there thinner too.
Davey
Davey
Thinking $250 for a pair of sides w/fenders. Only one good set of step up's (in front of the rear fender, directly behind the cab), one header and one rear panel. No cross-members, but I do have a few Flareside tailgates in nice shape. For anybody interested I'd work out something depending on what they need. I've been stockpiling stuff in case something ever happened to my Flareside.
No problem. I recall seeing another one of those locally as well, I'll keep my eye out for you.
OK, I'll take them. So that's $55 shipped, right? my email is rodneydhill@gmail.com please let me know how you want me to pay you. Thanks!
