F350 4x4 dually 7.3l diesel 76k miles
Year: 1993
Make: Ford
Model: F-350
Price: $4800
Mileage: 76000
Color: red
Private or Dealer Listing: Private Listing
Location (State): NY
Transmission: Automatic
Drivetrain: 4WD & AWD
Color: Red
Engine: 7.3l N/A
1993, f350, 76k original miles, 7.3l diesel motor e4od automatic trans, 4x4 dana 60 front sterling 10.25 rear $4800 located in upstate ny
new gastanks, new differential cover, steering gear box, new international CDR valve, new driver hub, headlight switch, radiator, thermostat, new brakes and calipers&rear shoes, all 6 tires new, new driveshaft u joints, new inner and outer tie rod ends, new steering stabilizer, serpentine belt,a/c idler pulley,tensioner pulleys,belt tensioner, 8 new BB code injectors with return line kit, new injection pump, brand new seat,transmission mount ,output shaft seal, truck has a omaha standard flatbed, 9.6 foot long 8 foot wide, pintle mount plate, fresh alignment and wheel balancing, fuel lines and rear brake lines,electric fuel pump, 1.5" leveling kit in front
