What is the best Electric Cooling Fan kit for a cheap price
Looking to remove my HP robbing fan clutch and go electric. I want one that is make spec for my 2003 king ranch 5.4 4x4. I dont want to drop a whole lot of money but I dont want a peice of junk either.I want it to last me for a long time with out any problems. Any advice is much appreciated, thanks in advance.
Originally Posted by BlitZ_
(Post 9384104)
JL |
Any suggestions Johnny on what fan to use and control system? As well as best installation spots?
Been interested for awhile, i think id rather build my own as well. |
Originally Posted by BURNSTOUGHFORD
(Post 9385404)
Been interested for awhile, i think id rather build my own as well. JL |
Awsome, thanks johnny. I know where there is a cougar in a junkyard near here. Might have to go see what they want for it.
(Post 9385554)
JL |
Im not going to rig anything up I want a direct bolt on kit thats spec for my truck. If I have to spend a little extra money to get a good one then I will but im not doing any kind of fabrication on this mod its just not worth that much effort to me.
(Post 9391666)
JL |
well if you want to do the fabing ive got the $$$ 03 f150 king ranch 5.4L 4x4
(Post 9391705)
JL |
Here's the fan controller I like to use:
Derale Cooling Products 16749 - Derale Performance Deluxe Adjustable Controllers with Pipe Threaded Probes - Overview - SummitRacing.com You'll need a high-amp relay to actually power the fan-use the relay on the fan controller to trigger the high-amp relay. Here's the high-amp relay I like to use: Terminal Resolutions has Wire Terminals, Automotive Wire, Battery Terminals & Electrical Supplies It can handle the startup and continuous load from the fan-you'll need two of these if you want to run the high-speed with a thermal switch or with a manual override switch. JL |
ok post the ebay links away
Hey Johnny Langton, I am trying to do this mod on my 2001 Ford F-150 5.4L Crew Cab. The link you gave for the High Amp Relay doesn't seem to be working. Can you repost it for me? Also do you have any photos that show your mod? How you mounted everything up? Thanks!
