H-D Supercharger Pullys-Needed
Does anyone know where I can get a 8.47" lower pully for my 2002 H-D 5.4L? My local hot rod guy says this will work best with the air intake and chip mods I'm planning. (He also said there is a 9" available that will boost +6 P.S.I., but he warned he has heard of rod failure ustng this much). Coments/suggestions?
Thanks, JJBoyd |
Click "Online Store" on the top-right and then go to the section with the race flag. You'll see the pulley you want there. Do not run that truck with a pulley unless the chip is programmed for it.
You are pretty much crazy if you go with anything more than 6lbs over stock. I think that is pushing the envelope. If you want to keep your truck safe and conservative go with 4lbs over stock.
