jumbofordman |
09-20-2010 02:42 AM |
Many parts 78 F-150 NEW PRICES, 2011 updated list of parts available
I flipped my 78 F-150. I have a bunch of parts that need to go. Some smaller items can be shipped, but most will need to be picked up. I live near Greenville, NC.
http://i720.photobucket.com/albums/w...915_182635.jpg
http://i720.photobucket.com/albums/w...914_183113.jpg
- 400 Clutch. Not many miles since I changed it, 12" Long style with new McLeod flywheel. Selling clutch, pressure plate and flywheel as a matched set. $100.00
- 400 engine. Been sitting in my garage since pulled 5+ years ago. Was running when pulled, but probably the best use is pulling the crank and rods out and using for a 351M to 400 conversion. Has 2bbl carb. I was keeping it as a spare, but I've never had any engine problems. $150.00
- 400 block. Have removed intake and cam, timing cover. Get that 400 crank, rods and pistons and transform your 351M. $100
- PS pump $25.00
- Dana 44 Front Axle 3.5 ratio open diff complete with Warn Premium Hubs $300.00
- Rear axle 3.5 ratio open diff Ford 9" 31 spline $200.00
- Ford NP205 Transfer Case $200.00
- Front Driveshaft $40.00
- Rear driveshaft, lengthened for 3" lift, longbed. $50.00
- 2 year old carpet, black with holes for transfer case and transmission lever $50.00
- Front seat from 90's F-150, will fit 67-96 Ford trucks, blue with armrest $50.00
- Headers, fairly new, for 4wd 400 engine 77-79 F-150. Buy the headers and mufflers and you can have the complete exhaust. $50.00
- Mufflers, Dynomax (2 available) $25.00
- Rancho 3" Front Coils (could also provide all parts for a lift) $50.00
- Superlift adjustable track arm $50.00
- Big Block 4wd C6 Automatic Transmission $200.00
- Ford 9" Center section. 3.5 ratio, open diff, 31 spline $150.00
- Grille, Grille panel and square headlights $100.00
- Ford 9" rear end, from 78 2wd, unknown ratio and splines $150.00
- Alternator $25.00
- Starter (for 351M/400 with manual transmission) 2 available $25.00
- Parts needed for front disc brake conversion on a 2wd 67-77 F-100. Kingpin style twin I beam, brake calipers, master cylinder. Everything you need except the brake booster. $150.00
