Raptor 6.2 vs Porsche Cayenne Turbo
So ski season is around the corner and I'm itching for a new toy
I love the Raptor 6.2 but I may need an SUV so thats where the Cayenne comes in. I've seen some used turbos in the mid $30s so the prices are comparable So which is better for serious snow ? Off road ? |
Off road, rough: Raptor
Off road, European Rally, I'd have to look at the driver's record. I bet the Raptor would give it a run for it's money with a 6.2. With a 5.4, Porsche. Snow: Which ever has the better tires, although if you are talking really deep, unplowed snow: Raptor. IMO, I'd rather have a new Ford with a warranty than a used (and who knows how it was used) turbo Porsche. If I won the lotto, I'd buy new--one of each. jmo, ymmv |
First, what year model Cayenne?
You should know that the all-new 2011 Porsche Cayenne, no matter if its a base Cayenne, Cayenne S, Cayenne S Hybrid or high-end Cayenne Turbo have a single-speed transfer case with locking center differential, no low range off road gearing. The older pre 2011 models have a more traditional heavy-duty two-speed transfer case with low range off road gearing and locking center differential. It seems strange to compare a Cayenne SUV to a Raptor pickup truck. The Raptor is a true heavy-duty 4x4, and thus better than a Cayenne in terms of off road capability. |
Originally Posted by GlassLeather&Wood
(Post 9343783)
You should know that the all-new 2011 Porsche Cayenne, no matter if its a base Cayenne, Cayenne S, Cayenne S Hybrid or high-end Cayenne Turbo have a single-speed transfer case with locking center differential, no low range off road gearing. The older pre 2011 models have a more traditional heavy-duty two-speed transfer case with low range off road gearing and locking center differential. I was just thinking since they are both high performance vehicles they would be a good match. I also heard the Raptor has a 100mph cut off chip bcus the tires would blow off the rims at 115mph |
Believe it or not, the Cayennes and Touregs are HIGHLY capable offroad in factory specs.
I'd probably take one over a 4runner, or Jeep Grand Cherokee (comparing new of course). Now, if you're cruising through a foot of snow and need to keep a pace, definitely the Raptor. Purely off-road, the Raptor is going to treat you better (ride) than the Cayenne will. It's good in the rocks and such. You'd need new tires on a Cayenne to traverse snowy passes - and you already have a GOOD set of rubber on the Raptor. The thing about the 2 speed transfer case is interesting. I understand why they ditched it, but lo range is always good to have. I'd say, if you can live without the amenities of the Cayenne, then you'll be fine with the Raptor. They really are two different vehicles that each have their own appeal. The 6.2 Raptor will be faster than the 5.4, but it's not going to be by any means fast... just so you know. Those heavy 35s take its toll on the power of that truck. Also, any tire you put on the Cayenne to make it capable in the snow will realistically be limited to ~100-120 mph. You can't have that exceptional traction without sacrificing something (speed in this case). [youtube]OEcr8N7bzFQ[/youtube] Around 1:40 shows some pretty difficult stuff. -rockstate -rockstate |
Originally Posted by rockstate45
(Post 9345942)
I'd say, if you can live without the amenities of the Cayenne, then you'll be fine with the Raptor. They really are two different vehicles that each have their own appeal. The 6.2 Raptor will be faster than the 5.4, but it's not going to be by any means fast... just so you know. Those heavy 35s take its toll on the power of that truck. Also, any tire you put on the Cayenne to make it capable in the snow will realistically be limited to ~100-120 mph. You can't have that exceptional traction without sacrificing something (speed in this case). |
Hmmm....
difficult is a relative word , the most difficult thing about the vid was the music ... :confused: pretty sure my Ex wouldn't have any issues with that mud road :-hair and the raptor could probably lap it in 23 seconds :-X04 |
Haha okay very true, but it was a quick find with a Cayenne in it.
Here's a Toureg (same platform as a Cayenne) doing everything a H2SUT will do on Hankook Dynapro ATMs. Not bad given the Toureg is running stock tires. [youtube]22zxOi1sXi4[/youtube] -rockstate |
People don’t usually associate the Porsche Cayenne with off road. Probably because it doesn’t "look" like a real offroader. But it’s a good practice not to judge a book by its cover.
The Cayenne does have all the necessary tools for off road use, and then some. ● Powerful engines with high torque output There are several available. ● Heavy duty transmission To handle the torque from the engines. ● Heavy duty traditional transfer case unit 2003-2010 models have a 2-speed transfer case. 2011-onward models will have a single-speed transfer case, this is their only shortcoming). ● Locking center differential Permanently locks the torque split between the front and rear drive axles to 50/50. ● Optional locking rear differential Permanently locks the torque split between the left rear and right rear drive wheels to 50/50. ● 4-wheel electronic traction control. Porsche refers to this feature by another name: "Automatic Brake Differential" (ABD). ABD (a.k.a. traction control) forces the open front and rear differentials to act like limited-slip differentials by inducing a ABS brake apply and release cycle on the slipping (spinning) drive wheel(s). Note a locking rear differential is available. ● Good obstacle clearance with decent wheel travel. ● Drivetrain and driveline components are tucked neatly up under the vehicle to reduce the chances of snagging them on something. ● Available underbody skid plate protection and Hill Decent Control. Hill Decent Control (HDC) sort of replaces low range gearing in the 2011 models to allow the vehicle to crawl down a steep hill at low speeds (around 3-5 mph). But there is still no electronic feature that can truly substitute for low range gearing. Here are some stills of Cayennes off road, much more severe than pre-staged product demonstrations. <a href="http://www.imagebam.com/image/578c7598579044" target="_blank"><img src="http://thumbnails32.imagebam.com/9858/578c7598579044.jpg" alt="imagebam.com"></a> <a href="http://www.imagebam.com/image/22ed5a98579049" target="_blank"><img src="http://thumbnails25.imagebam.com/9858/22ed5a98579049.jpg" alt="imagebam.com"></a> <a href="http://www.imagebam.com/image/c0e6fd98579057" target="_blank"><img src="http://thumbnails14.imagebam.com/9858/c0e6fd98579057.jpg" alt="imagebam.com"></a> <a href="http://www.imagebam.com/image/01aff198579055" target="_blank"><img src="http://thumbnails32.imagebam.com/9858/01aff198579055.jpg" alt="imagebam.com"></a> Straight out-of-the-box the Cayenne is a decent offroader even with factory tires. However, the Raptor, also straight out-of-the-box is far better an off road vehicle. It would be more logical to compare the Cayenne to a regular F-150 4x4. |
A Cayenne is better off road than you imagine something with a Porsche badge to be but if you want a true off roader w/ a full sized body then a Range Rover, LR3/4 or Toyota Land Cruiser are the ones to get...a Cayenne can't get close to any of these when the going gets rough...just beware the euros are very complex and repairs are expensive
Originally Posted by 85e150six4mtod
(Post 9343782)
Originally Posted by HUBBSTER
(Post 9343291)
They are both pretty capable off road vehicles but if you get the Cayenne 1. Your car will be named after a spice instead of a dinosaur. Which would be the deal breaker for me. :)2. You think the Cayenne looks good? I mean if your looking for off road capabilities why not a Land Rover Disco or Range Rover.
(Post 9343291)
I love the Raptor 6.2 but I may need an SUV so thats where the Cayenne comes in. I've seen some used turbos in the mid $30s so the prices are comparable So which is better for serious snow ? Off road ? Having driven the CT on the racetrack I can tell you that it is one seriously fast SUV. 500 HP 0 to 60 - 4.4 Seconds.... The air suspension which is standard on the turbo is great. It allows you to raise the SUV if you want to go offroading but if you are going seriously fast it lowers the vehicle to improve it handleing..very nice. |
Originally Posted by fordtruckman
(Post 9375841)
