how to replace a brake line
replaced the line over the rear on the 90 f 250 today, and thought Id take ya'll along for the ride.
find the leak http://i620.photobucket.com/albums/t...akeline001.jpg remove the line ends http://i620.photobucket.com/albums/t...akeline003.jpg open the clamps http://i620.photobucket.com/albums/t...akeline007.jpg set up the tools, measureing tape, magic marker, cutter, and flareing tool kit. remember that brake lines require a double flare http://i620.photobucket.com/albums/t...akeline008.jpg set the line you removede next to the new one http://i620.photobucket.com/albums/t...akeline009.jpg measure the 1st bend http://i620.photobucket.com/albums/t...akeline010.jpg make mark on new line http://i620.photobucket.com/albums/t...akeline011.jpg place center of bender on mark, and bend http://i620.photobucket.com/albums/t...akeline012.jpg continue this process untill all bends are made. the line is too long at this point, so measure, mark, and cut it with the tubing cutter. do not use a hack saw, it will leave a rough edge http://i620.photobucket.com/albums/t...akeline013.jpg http://i620.photobucket.com/albums/t...akeline014.jpg set up the flaring tool, with the double flare adapter in it http://i620.photobucket.com/albums/t...akeline017.jpg remove the adapter, and flare it again http://i620.photobucket.com/albums/t...akeline018.jpg flare should look like this. if it has any rough edges, clean it up with some emery paper, make sure to blow off any dust http://i620.photobucket.com/albums/t...akeline019.jpg put line back on, use care to keep it straight when starting it, or you will cross thread the brass, and have to start over http://i620.photobucket.com/albums/t...akeline021.jpg tap the clamp lightly with screwdriver handle to lock in the line http://i620.photobucket.com/albums/t...akeline022.jpg hook up other end, and clean off all spilled brake fluid with brake clean bleed the brakes, I use a clear tube into a clear jar, so you can see the bubbles. http://i620.photobucket.com/albums/t...akeline025.jpg check for leaks, if none, your all done. thanks go out to Bud & Jr for help in makeing this thread:D |
Nice job, Charlie....that was easy! Nice to have that EASY button.
Originally Posted by BPofMD
(Post 9295333)
Nice to have that BUD button.
very well done Charlie :-X22
should help a few folks--I know many that won't attempt a hard line problem~~ |
Originally Posted by jr32560
(Post 9296469)
Really like your tube bender, great info. should've seen the silly straw line I had to make for the subaru.
Charlie |
Great job Chalrlie and company.
Originally Posted by 66fdtrucknut
(Post 9298186)
Charlie
Originally Posted by tiny1
(Post 9298296)
