Reset TPMS 2011 F350...please help! :)
Just got larger tires on my truck and tire pressure monitor light is on. How would I go about resetting this? VERY much appreciated in advance!
Alan |
Discount tire reset mine when I got the tires... I assume the shop where you got tires could help..
Sorry - I din't know how to reset myself....:-X01 |
Place I had tires put on just said to drive over 45mph for a couple mins. and it would reset itself. That didn't happen. Anyone else have ideas?
Read the Owner's Manual?
Page 236 Owners manual
I left the damn thing at home, but I'm guessing it says to do what I had already done up to that point, which is to drive it for a little while over a certain speed and it will reset. Anyway, I took it down the street to the Ford dealer and they had to use their reset tool to do it...no cost, no big deal.
thanks for the suggestions of reading the owners manual. |
Originally Posted by admorris
(Post 9283159)
Originally Posted by boulderbronco
(Post 9311588)
What pressure are you running in your new tires? I just got new oversized tires today and they couldn't reset the damn thing. The max psi is 50 on these new tires so thats where they are. I can't imagine the TPMS on the F350 freaks out at 50psi!
Too late for you guys, but if you buy the proper tires for your truck you won't have this issue.
Originally Posted by bpounds
(Post 9311970)
Most load range E are 80 psi. What tire did you buy?
Nevermind, I see it in your sig. That is an E range 65 psi. Buyer beware I guess, which was the point I was trying to make. |
(Post 9315229)
Nevermind, I see it in your sig. That is an E range 65 psi. Buyer beware I guess, which was the point I was trying to make. Yea, not trying to bust your chops...I understood what you were saying. I just can't believe I am either stuck with 80psi car tires for my truck, or a damn warning light. Not everyone that owns an F350 tows 12k lbs or hauls 4k lbs in the bed. I'm really hoping there is a workaround for this, as I cannot possibly be the only one who has replaced those go-kart tires for mud tires. |
(Post 9311588)
I talked to a ford service advisor today about a re-flash and the low tire pressure warning and he said that these sensors will send an alarm at any pressure under 55 psi. because these tires are rating for a minimum of 65psi. and max of 80psi. I had the warning this week when a tire got 54.5 psi. He also said that if you get after market tires and rims you need to use the sensor valve stems or stare at the low pressure tire light indicator. Or put a piece of tape over the light. Thats what Rancho Ford said.
Originally Posted by Rick Cargo
(Post 9315679)
Hey Rick, I would be ok with 55psi, but I'm getting light at anything under 62psi. From what I understand, the tpms comes on for any pressure 25% below the Ford specs (65 front, 80 rear) which would be 60 rear and 48.75 front. Are you saying that anything under 55 all the way around is what is needed to throw off code? |
