No Oil Pressure and Engine Knocking. Help please!
I have a 2003 F150 Heritage Edition 5.4L Triton V8 4WD with 70K miles. Changed oil like I routinely do with Pennzoil 5W20 1 week ago. Has been running great and ran great yesterday til I parked and shut off truck to run inside for a few minutes. When I came back and started the truck immediately had engine chattering/knocking and no oil pressure. There are no leaks anywhere. Checked the dipstick and dipstick was wet. Oil looked fine and clean. Changed oil and used different filter (thought maybe bad filter?) and still no change. Any suggestions? I appreciate any help! Thanks!
Originally Posted by spiffySMR
(Post 9280613)
JL |
Thanks for the suggestion! Having someone check it out and hope it will be something kind of simple like that versus anything else. Appreciate your help! :-wink
DROP THE PAN NOW!
Get in there and look it over, something is wild wrong - you know it. It could be a clogged sump filter, or it could have a hole in the filter where the screen let go and junk got grabbed up by the snorkle - and rammed into the pump gears. ZERO OIL PRESS is a clear sign of catastrophic engine failure. DON'T run it again without a disassemble. WORD: (Now this is an old story for ya, this happened around late 1977) I knew a guy who bought an old surfer van that some joker dropped a 302 into (it was originally an I6 Econoline). Because the pan drain ended up on top of and in the center of the crossmember, the oil was never changed. MEGASLUDGE built up in it, and one day on the way home from the bar (Senor) 'Hartley' experienced massive oil pressure failure..... Enough "GUNK" had built up to cover the coarse screen on the oil pickup in the pan so that it could suck all it wanted without flow. Because the pump was mechanichally driven it persisted. The suction tore the wire screen out of the bottom of the pickup tube strainer and it instantly gulped a wad of sludge into the pump gears. QED: The gears stopped! The drive shaft for that pump was a hexagonal shaft about 5/16's inch, and when we pulled it out it looked like a twisted piece of ornamental wrought iron suitable for any balcony in New Orleans.... |
trade it in or get a rebuild ................. no pressure and a knock is bad , bad , ju-ju !!!!!!!!!!!!!!!!!!!!!!!:-X09
(Post 9283416)
Got a guy looking at it today and he's supposed to let me know the damage. Crossing my fingers but not getting hopes up either. Thanks everyone for the suggestions!
Sometimes miracles do happen!! Best of luck to ya!!
