Just a :-X22 for Jeff, he quoted me a price and shipping and sent it out when it ran way over on the shipping, before even knowing if I would cover the additional cost. That's a stand-up guy. Thanks again Jeff, great dealing with you.
Hi Jeff, fe 360/390 intake manifold w/ egr?
Thanks, Bart |
Nope, sorry.NOS FE exhaust manifolds id like to see gone though.
Jeff |
I'm looking for frame to engine perches to put a 300 in my highboy, I saw posted way back you had a pair did they go?
Originally Posted by brycam00
(Post 14381471)
Jeff |
Hi Jeff
looking for new doors and front fenders for 79 f250 . also grill housing steel chrome not the aluminum. let me know what you have and send pics if possible thanks |
I have NOS fenders, no doors right now. I am not familiar with a steel grill in the small truck series, only the medium duty. I do have NOS shells for 73-77
Jeff |
Do you have the radio support bracket that attaches to the bottom of the radio in the 73-79 F100/F150's? It is 'S' shaped and has a single bolt that screws into the bottom of the radio.
Steering column parts? Specifically the lower bearing with white plastic surround that keeps the steering shaft centered in the column? Turn signal switch? Bench seat? Dash bezel for 2 post radio? 6" lift springs? Miscellaneous parts I don't know I need yet? All of the above are to go into a 76' F100 with NP435, Dana 21(unfortunately), 351W with a 78' front clip. |
door panels, 3 female seat belt buckle assemblies, and 1 male lap belt. (BLUE)
I need a rag joint like the one in the pic.it's for a 78 f150 2wd auto. price shipped to florida 34609 if you have one please.
http://i54.photobucket.com/albums/g8...psd9c7233b.jpg |
Do you have an automatic column for a 76-77 4x4?
rear sump oil pan for a 400? with pick up and main stud?
Hey Jeff need suspension parts for a 1977 highboy F250 all hangers and springs for the rear. let me know thanks
Ryan |
Originally Posted by Black500
(Post 14393700)
Steering column parts? Specifically the lower bearing with white plastic surround that keeps the steering shaft centered in the column? Turn signal switch? Bench seat? Dash bezel for 2 post radio? 6" lift springs? Miscellaneous parts I don't know I need yet? All of the above are to go into a 76' F100 with NP435, Dana 21(unfortunately), 351W with a 78' front clip. No on springs and seat, will check on radio bracket, is bezel for air or no? The bearing and switch, used or NOS? Jeff |
Originally Posted by derbydad276
(Post 14475475)
Jeff |
