55 F100 Gas Tank Removal
This weekend I would like to remove my orginal gas tank and since this will be my first experience, is there anything in particular that I need to be aware of? It appears to be a simple process but I know that sometimes what appears simple can be misleading. Thanks for any tips.
All very straightforward, Steve. Remove your running board and have at it.
himmelberg |
Originally Posted by Steves55
(Post 9202988)
before you even mess with it get some penetrating oil and spray those threads on the straps.
Originally Posted by Old F1
(Post 9203318)
(Post 9204458)
I am going to either use a polyproholine (spelling) or a steel tank from LMC; haven't made up mind yet. My original is just about shot and I think that it has been the source of my problem with my carb.
Originally Posted by tardster
(Post 9205435)
I got my new tank from LMC, I had thought about going with the plastic tank but then decided since the diff in price was only 20 bucks I'd go with the metal tank. Be sure to get new straps and rubber when you order your tank, I tried to reuse the old straps and someone told me to get new ones because they were easier to work with.
(Post 9206381)
Thanks for the tip regarding the straps. I will be sure to order a set along with new mounting hardware. My straps and hardware look like they have seen their better days. In-fact, I shot some PB Blaster on the bolts last night. I spoke with the nice folks at Mid-Fifties about their plastic tank and think I will go that route. Additionally it accepts the stock sending unit without needing an adapter. The only difference is that it is a 15 gal tank. No big deal..I like the idea that I will never have to worry about rust.
And just to be a smart alec, I recommend you empty it before you drop is out! Lots easier that way!
while PB blaster works, a 50/50 mix of tranny fluid and acitone works wonders. I've yet to have a nut or bolt stay stuck after a good soaking in that magic juice. FYI : it WILL eat paint and plastic. (dont ask)
Oh yeah! That will be the first thing I do. Thanks.
55 Gas Tank Removal
I am in the process of "trying" to remove my old gas tank. I removed the running boards with no problem at all however the bolts that hold the 2 running board braces are frozen. Do the braces need to be removed as well or do I just need to remove the 2 gas tank straps? Thanks.
(Post 9244306)
My braces were riveted on to the frame and I didn`t see a real need to mess with the rivets so they stayed in place and my tank came out ok after I loosened the straps.
