Oil pressure switch/sending unit location 302 efi
Where is the oil pressure switch/sending unit located on an 89 f150 with the 302 efi.
Thanks |
Just in front of the oil filter in the block, single wire pushed on over a stud on the sender.
i did'nt see it there but i did see one on top of block by fire wall. is that it..
The one on the back is a knock sensor. There's only one location for oil pressure.
This is your oil press sender. Ignore the oil cooler next to it. https://cimg6.ibsrv.net/gimg/www.for...5193cf3f66.jpg |
It's in the same place on my '95. With all of the accessories bolted on the front of the engine, it can be a little hard to see. I was going to try to replace it by standing by the left front fender, like when you change the oil filter. But, I think it'll be easier to access from underneath. EDIT: I was wrong. You can't even see it from underneath. Easier access by leaning over the driver's side front fender (like changing an oil filter).
There is a special socket you can buy/rent.
Originally Posted by Scndsin
(Post 18792074)
Somebody recently bumped a thread mentioning it as being 1-1/16.
I had a spare but can't lay hands on it to check. Think you have to use a 12 point. |
Originally Posted by Bronco638
(Post 18802606)
I have one if the OP needs it.
Thought we were all trying to help 99regal
:confused:
You're guess is as good as mine. 99regal99 didn’t appear to have a question. |
Originally Posted by 99regal99
(Post 18791510)
Originally Posted by ozziesstang89
(Post 18802479)
(Post 18802965)
The original post is from 9 years ago but it’s the thought that counts. :-X22
