'Blower Flasher Relay Block' location
I'm working on our '00 Expedition's HVAC b/c the front blower will not come on. I found a test procedure to run and there is no power at the EATC blower speed control box, so the next step is to check for voltage b/t at the blower motor relay socket terminal, specifically terminal # 87 which is the black / light green wire, which according to the test procedure is supposed to be located in the center of the vehicle behind the dash. However, I had the main EATC unit, radio, and drivers side of dash off this afternoon and did not see the relay anywhere.
Can anyone tell me where this is located? |
Turn the 4-way flashers on and follow the clicking. The flasher relay is in the same box above the driver's right foot.
Will do! Thanks projectSHO89!!!
Procedure to check for Power at the EATC
Hey MCM420 ... you said "I found a test procedure to run and there is no power at the EATC blower speed control box". What was the test procedure you used ... I have a similar issue.
Originally Posted by tjweber
(Post 14717918)
