f100 2wd chopped top
1977 FORD F1OO with chopped top, dropped suspension, 75 camaro front suspensions NEEDS FLOOR PANS driver window is cracked i listed as much as i can here there alot more im unsure of actual mileage
SPECIALTY PARTS diamond plate bed floor rebuilt holley 4bbl carburetor hookers competition headers weiand aluminum intake PARTS I HAVE BUT HAVE NOT INSTALLED keyless entry door poppers with solenoids bearclaw door latches with installation brackets security alarm high beam switch tail light sockets BRAND NEW PARTS H4 headlight assemblies with bulbs BATTERY STARTER SOLENOID BATTERY AND STARTER CABLES VOLTAGE REGULATOR ALTENATOR COIL PACK SPARKPLUGS AND WIRES DISTRIBUTOR WITH CAP AND ROTOR BUTTON AIR FILTER FUEL FILTER BRAKE CALIPERS HUBS AND BEARINGS BRAKE LINES BRAKE BOOSTER BRAKE MASTER CYLINDER BRAKE PADS FUEL PUMP FUEL SENDING UNIT FUEL TANK IGNITION SWITCH STAINLESS STEEL MOUNTING HARDWARE BED SILL WITH MOUNTING BLOCKS |
