4.9 ignition timing
10 btdc
Disconnect pos. Batt And distributor wire ...but where and how do u place the distributor?? I must have tried 20 setups. Gotta be a minor thing im missing. Anybody have a working sequence!? :D |
the distributor rotor turns CLOCKWISE , the distributor cap is installed with the marked # 1 position facing AWAY from the engine , and the engine cylinders / spark plugs are numbered 1 through 6 , from front to rear
For more help: Ford Inline Six Firing Order |
Yeaaaup. Thata what i was soinf. Thanks drew.
Must be a bad distrubutor. Thing doesnt even line up atraight...got bent |
Originally Posted by Breaker Breaker 3-3
(Post 9115282)
Must be a bad distrubutor. Thing doesnt even line up atraight...got bent I can go grab three tomorrow if need be. |
