1993 F-700
Could you decode mine? Vin# 1FDNF77J7PVA03353 Thanks. I an looking for a speedometer cable and transfer case linkage parts.
Originally Posted by audiveight
(Post 15930084)
Please help me with years, engine size, etc on the following two serial numbers.
D70BVCA8358 and C55CVA71354 Thanks. B = Caterpillar V190 3208 8 cylinder diesel or (1978) Cummins KT40 6 cylinder diesel. V = Kentucky Truck Assembly Plant. CA8358 = 1978. ------------------- C55 = C550 Tilt Cab. C = 330 2V Medium Duty FT engine. V = Kentucky Truck Assembly Plant. A71534 = 1976. |
1990 F700 Crew Cab VIN breakdown
1FDXK74A8LVA13862
1990 F 700 Has dump box on it now. Let me know what you can tell me on this. Heard about it from a friend. New to FTE! |
Does the pic help at all Bill?
Originally Posted by RedStroke
(Post 14887453)
Thanks for the help Bill. I believe the last 3 digits of the F80260 are the GVW. I saw another 30,000 gvw and its tag said F80300
See tag below. https://cimg5.ibsrv.net/gimg/www.for...1a150753b2.jpg https://cimg8.ibsrv.net/gimg/www.for...8aac43f67d.jpg |
I've got an F700 and I can't find much info about it. Maybe decoding the secret code will help!
F70CVDC7153 Thanks for any help!!! |
Originally Posted by F700Expedition
(Post 16264588)
F70CVDC7153 C = 429 4V V = Kentucky Truck Assembly Plant. DC7153 = 1979. |
Thank you!
92 F700 VIN
I know this thread is old but how would a guy go about decoding a vin on a 92 F700 vin: 1FDNK72P6NVA27258
any help would be appreciated... |
Originally Posted by 220Combat
(Post 16399663)
I know this thread is old but how would a guy go about decoding a vin on a 92 F700 VIN: 1FDNK72P6NVA27258
N = Class 6 - Hydraulic Brakes - 19,501-26,000 lbs. Gross Vehicle Weight Rating. K72 = F700 Diesel. P = 6.6L Ford Turbo Diesel. 6 = Check digit, FoMoCo use only. N = 1992. V = Kentucky Truck Assembly Plant. A27258 = 1992 Numerical Sequence of Assembly, the trucks specific serial number. |
I have what a believe is an F700 not sure on the year tho
the vin is f70cvfb2967 thanks in advance |
Originally Posted by aj3501
(Post 16616491)
I have what a believe is an F700, not sure on the year.
VIN: F70CVFB2967 C = 429 4V V = Kentucky Truck Assembly Plant. FB2967 = 1979. |
Thanks a million Bill, I really appreciate it, have a great day
1979 vin
i know this thread is a little old but I am looking at a 1979 F700 and the warranty sticker or plate is gone or painted over according to the guy that owns it now, the vin is F70CVEE9098 is there anyway to find the gvwr from the vin?
Thank you |
1 Attachment(s)
Originally Posted by ldfry001
(Post 16728387)
Thank you GVW stamped on the 3rd line, far left (see pic below). Safety Standard Certification Label glued to the B pillar below the striker plate, has front/rear GVWR's printed on it. But, if it got wet, it could peel off. martiauto.com has ALL the original 1967/79 FoMoCo records, but charges for any info. Passing along your VIN will get a copy of the original build sheet, can also supply a new Warranty Plate with all the correct info on it, ditto for the Certification Label. F70 = F700 (gas). C = 429 4V (7.0L). V = Kentucky Truck Assembly Plant. EE9098 = 1979. Pic: Parts catalog example of the 1973/79 Warranty Plate. |
