where to find pneumatic couplers
I am looking for pneumatic couplers like these for a 1/2 inch air hose (for a train horn).
Where can i find these (preferably locally)? http://3.bp.blogspot.com/_ynWOAg4YQB...20Mod%2000.JPG |
I haven't had much luck find those locally. A couple of ideas would be high end computer stores, those fittings are used in water cooling processors. Maybe aquarium stores.
If you get in desperate need, you can use brass ferrule fittings. Ace hardware, lowes, home depot should have something that will work for you. You might look there anyway, say in the irrigation section. |
Originally Posted by ReAX
(Post 9056179)
Try McMaster-Carr. LINK
They are also available a heavy truck part houses; they are used in air brake assemblies and other pneumatic systems.Iget mine locally.
McMaster Carr, Grainger, Festo
Truck parts place, like stated above, should have them for d.o.t. airbrake systems. Running d.o.t. tubing is a good idea as it is rated for service brakes at a wide range of temps.
think about PEX fittings ? I don't know if they make what you pictured in 1/2 inch ?
but pex does and it has all kinds of fittings http://t3.gstatic.com/images?q=tbn:A...X7WuUqufajTRzu |
Fittings
Any truck shop/stop , and any Napa store . If you have a air ride supplier dealer in your area . Pretty commen air fitting . :-drink
He's looking for 1/2 id those aren't common IMHO
Fittings
Half inch air line is a common size , I have it in 1/8" - 1" line . They make air line in rubber and hard line that is made from PVC Synflex DOT approved line . The fittings are made in brass and plastic . I like to use brass over the push-pull plastic design . Most good auto parts supply houses carry have most sizes in stock . |
Good to know
Thanks I have not seen the larger stuff |
hornblasters.com
