How to replace Door glass in 1952 F-1
Can someone help this newbie out. I need to replace the passanger side door glass (roll up window) in a 1952 F-1. I'm not sure how the glass comes out of the track.
Thank you, Matt |
It comes out thru the door access panel hole .Roll the window down .Remove the 2 clips that hold it to the bottom window channel .Roll the window regulator up a little . Window will drop down .Tilt and remove .
Thank you. I will try to do it tomorrow.
52 DRIVER SIDE WINDOW
Hi, I new to this forum. Have a 52 f1. Once you remove the window from the door, the glass itself is attach to a steel U shaped mount. Removing this is tricky so if you don't need to replace the glass, leave it be. If you do, use a rubber hammer gently, no screwdrivers or the glass will break. Also there is webbing in between the glass and the steel mount which will have to be replaced to seat the glass to avoid chipping and excess vibration. Hope that helps.
To remove bottom glass channel on door glass introduce the channel to a heat gun . This will loosen up the welded on glass setting tape from 60 yrs. ago .This worked for me .Later , Denny
Thanks for the tips. I just came back to this post to report I was able to get the Window out but I was not sure on how to get the glass out of the channel.
Thanks, Matt |
Originally Posted by capone1680
(Post 9038472)
Thanks, Matt |
windows wont roll up or down, what is the issue? like what aprts to i need to buy or replace etc. also the door handles dont work. driver side works from the outside but not inside(doesnt matter placement of handle inside). Pass works the same but you have to have the handle in the right place on the inside(will not open from inside).so same question what do i need to buy or replace ti fix?
