Ford Truck Enthusiasts Forums
-   Explorer, Sport Trac, Mountaineer & Aviator (https://www.ford-trucks.com/forums/forum32/)
-   -   Transmission Range Sensor (https://www.ford-trucks.com/forums/962908-transmission-range-sensor.html)
wmcvetty 06-04-2010 10:07 AM
I have a 95 ford explorer sport that has been giving me issues starting to the point that I had to move it to neutral, then sometimes reverse before it would start. I am told that matches the symptoms of the transmission range sensor going out.
I have the part, and I have gotten all but the center nut off, and man it is not budging. Any time I try to move it the manual shift lever pops gears on me. Is there a way to lock that down so it does not move while I losen the nut?
Thanks,
Walter
wmcvetty 06-04-2010 01:32 PM
Well, leaving the shift cable on did not do it! Now I need to replace that stupid thing - they tend to break if you put to much pressure on them :mad:.
For the record, I put it back on and then went back out and forgot that I had done so. I was reminded quickly as I heard an strange snap. Followed by a few choice words.
Of course, the transmission shift cable is a dealer only item, or junk yard.
