1995 F150 Speed Control
Read all the threads, including SUBFORD's excellent manual excerpts with ohm readings from the servo. Everyone of them checked out good for me. However, got an issue still.
All break lights work. Master Cylinder Switch recall complete, and works. New servo Still no Speed Control. Everything seems to work great except that button that turns the damned thing on. Checking between the wires indicated I got perfect readings on my multimeter for every button, unfortunately there was no, ON test. What could I be missing? |
I'm watching this thread. I have the exact same problem.
Does the horn work?
Yup horn works.
Does the speedometer work OK with no jumping.
RABS yellow light on? Did you check all the fuses both under the hood and in the dash? / |
No RABS light
Speedo works great, never even seen the rabs light.RABS? Rear Anti-Lock Brake System?
Curious though, the wiring diagrams show the PCM going into pin 8 on the amp/servo harness on one sheet while Pin 2 is the brake pressure switch from the end of the master cylinder, but the other shows the pcm going into pin 2. I have always thought it was something in the Speed Sensor |
Originally Posted by Scinner
(Post 8881722)
(Post 8881722)
(Post 8881722)
http://i54.photobucket.com/albums/g9...ControlAmp.jpg http://i54.photobucket.com/albums/g9...edControl3.jpg http://i54.photobucket.com/albums/g9...ontrol31-1.jpg http://i54.photobucket.com/albums/g9...dControlTS.jpg / |
OK, everything seems to be correct.
One thing I dont see and cant find on my truck, an indicator light on the dash. Am I just plain stupid, or is there not one? I thought about checking that bulb, when I seen the posts regarding stop lights, and then it hit me, there isnt one. WTF? Perhaps my dash panel had been replaced by the previous owner and they put a different one in? Could that affect it? I know the amplifier receives it signal from the PSOM, so maybe that return is missing as well if its a different panel.... |
Also, I dont have just Rear ABS, but 4 wheel ABS, hence the only dash light is ABS, however, it works fine. Light come on at start up like every vehicle, then clears out immediately. Does that mean i still have a separate RABS module?
ok checked ac voltage between 3 and 10 on amp harness. i seen 6mv in park and watched it fluctuate as i drove down the driveway. current speed is getting to the amp. switch signals getting to amp. 12v on p7 when key is on. im out of ideas!
got it!!!! Pin 9 should have 12v normally, and that was my problem
the mc switch is good, 12v getting through that harness and eerything, however, somewhere in the loom is an open. I fed a wire from the switch return, as not to actaully bypass the switch, and then cruised around at 35 mph with everything working great!! That wiring diagram is what did it for me. Thanks a million, Subford |
(Post 8893123)
(Post 8893162)
Do you have front wheel sensors? If not you do not have 4 wheel ABS.
(Post 8893542)
the mc switch is good, 12v getting through that harness and eerything, however, somewhere in the loom is an open. I fed a wire from the switch return, as not to actaully bypass the switch, and then cruised around at 35 mph with everything working great!! That wiring diagram is what did it for me. |
