49 5 Speed Overdrive
Anyone interested in a good one. Figured I would ask before I shop it around. Should fit F3, F4, F5, F6, F7, & F8 for a lot of different years.
<!-- / message --> <!-- controls -->http://images.ibsrv.net/ibsrv/res/sr...c/progress.gif |
Can you post a picture and where are you located? Is it syncro?
As far as I know Ford didn't have a five speed in '48-52, just the three and four speeds.
If interested PM me. Ford did have a 5sp in 49 and I can open it up and get pictures.
Lincoln 337cid
I apologize, I wasn't thinking about the larger F-7 and F-8 trucks.
http://www.fatfenderedtrucks.com/sca...2_5speed01.jpg http://www.fatfenderedtrucks.com/sca...2_4speed02.jpg If it's for the F-7 and F-8 with the 337 I would doubt it would fit the smaller flathead and if it did it would be a low geared heavy beast. From the drawings it looks like they have different mounting surfaces. I'm sure it would take a lot of modifications to make it fit the frame without any benefit but I could be wrong. |
That's a big, big tranny...
Great minds... eh, Bob? |
Ross, I beat you to it!!:-X04
Thanks for the diagrams.
Nope, at least not identical. In 53 they came out with a new model.
Will this five speed fit a 54 f600 with a 239 yblock? are the bell housings the same?
Originally Posted by fifty-two_f1
(Post 8841558)
F7 and F8 used the bigger flat V8 (337 cid) and the 5 spd trans. The 5OD was standard on the F7 and optional on the F8. The plain 5 spd was std on the F8 and optional on the F7. IF I remember what the shop manual and operator's manual says. |
But if he used the bell from his F-600 Y-block, would the 5OD bolt up to that, and be the right length to flywheel?
BTW, the upper of Bob's pictures is the 5OD, and I don't see any synchros...? |
I dont know if you guys are familiar with the 60s internationals, but they used 3 and 4 speed trans that should bolt right up to a ford. I have a 63 c1300 with a straight 6 and it has 4.88s and is SLOW. It has a three speed and a five speed with overdrive would be sweet for that truck. and if it did not bolt up as planned then it should go in my 54.
Oh shoot, I don't know - I didn't see he was talking about a '54 and Y block - must have only seen his user name. Talking before thinking again - sorry.
