R&R Y-Pipe withough removing turbo?
I think I have read somewhere that you can replace the y-Pipe without removing the turbo. Does anyone have a procedure?
I did mine with removing the turbo. I didn't know you could do it without removing the turbo.
I'm not sure how you'd get it out without removing the turbo as I don't think there's any way to wiggle it out underneath. Removing the turbo is SO much easier than trying to fight it out underneath anyway and at MOST all you need is the $10 turbo gasket kit. You have an 03 so it's a LOT easier than the later models IMHO. If you're replacing the y-pipe because of a broken flex bellows on the passenger side then that can be done without removing the turbo but it's still a PITA.
Originally Posted by KRDiesel
(Post 8760448)
https://www.ford-trucks.com/forums/7...tructions.html |
Originally Posted by amdriven2liv
(Post 8761279)
(Post 8760448)
tas working on it, but i broke a few bolts and ran out of time. So i am restarting the project.
Gotcha. At least it warmer now.
