That is one beautiful super camper special Cinematycoon has. would love his email or contact info so I could ask him some questions..if anyone knows this guy please let me know.
Seriously. That is a beautiful restoration. I can only hope to make mine that sweet.
contact info
Hey dh320 just click on my name Cinematycoon
https://www.ford-trucks.com/forums/member.php?u=326711 and click on download vcard information. (you need to be logged into get it) I would post it here but I do not want to be overly spammed (like Im not already) Or post your email in my gallery. https://www.ford-trucks.com/user_gal...&albumid=21433 Thank you for the complements. |
just finished front end 3 inch custom lift in my 79 f150 custom
rear was alot simpler just blocks and new ubolts lots to do got to finish motor transplant body job and new paint box job also some frame renos a pach here a crossmember there not to bad also a total break job from lines to linings well thats what happens when they sit in the bush for about 4 years still got to love em |
engine rebuild
My name is Jimmy
I have a 1973 F-100. Have been looking far rebuilt 360 engine. Mine has been rebuild once before. I m thinking of putting a 351 W in it. What do I have to change in order to use the 351, and is it worth it? |
#1 Motor mounts #2 different Bell housing since your going from a Big block to a small block possible longer or shorter DS but hopefully you won't have to. If you do go with a 351W make sure your exaust doesn't interfear with your steering on the drivers side. Make sure you have all your brackets for the 351 since your old brackets won't work unless you do some mods to them. Don't forget to make sure your exaust will bolt up your exaust manifold on the 351 if it doesn't you'll need to put new on.
FordF100 restoration project
Just arrived on this site this evening as a new member... have ordered and starting a new build .... can I ask any tech questions yet?
Ask away, if the guys on this forum can't answer it then the problem doesn't exist. You will want to ask using your own thread instead of adding to this one that is dated from 2014?
Ford F100/150s rule
Originally Posted by Jetfixer-6
(Post 19632178)
