89 fullsize Bronco 4x4
89 ford bronco fullsize, 4x4 , 150,000 miles, BAD CLUTCH!! will barely even move.... New clutch from advance is only $130 but i don't have time to put it in and i won't. buy it and part it out or fix it and drive it because it was a great truck. please don't bother me about fixing it.
It ran and drove great before the clutch randomly gave out about 2 days ago. the steering and suspension are tight and it stops great because it had all new front brakes put on not too long ago.-- new tires. it was a daily driver. - it has a good running 302 5.0l v8 engine, fuel injected, no smoke and no noises, runs great has plenty of power. -good 5 speed manual trans, m5r2 - good transfercase (4x4 works good), manual shift <<<<< reliable - WARN PREMIUM, manual locking hubs <<<< reliable - GOOD rear end. 8.8 ford will fit trucks/broncos etc. 3.55 gears with factory limited slip posi unit , WORKS GREAT. brakes are good. TAILGATE IS RUST FREE. its solid underneath. body isn't in too bad of shape compared to most bronco's. no floor rust, etc.. here's some pics-http://i280.photobucket.com/albums/k...onco4x4003.jpg http://i280.photobucket.com/albums/k...onco4x4001.jpg http://i280.photobucket.com/albums/k...onco4x4002.jpg http://i280.photobucket.com/albums/k...onco4x4005.jpg http://i280.photobucket.com/albums/k...onco4x4004.jpg http://i280.photobucket.com/albums/k...onco4x4007.jpg located in pennsville, nj 08070. can be at philly airport in 30 minutes. 5 minutes from delaware mem. bridge. email- pbawboy67@aim.com thanks:-D |
Pictures
I can't see the pics at work. Can you pm or email me some. Thank you. I'm in Ct.
email: mckayt@aetna.com |
Still have it.
the bronco
just looking to c if you still have this bronco i am wait for the check for mine that was just totaled and shoping for a new one
It's in parts and peices bud....too late.
Only thing left is the motor, rear, tailgate, doors, Tcase.....I sold the trans and fenders,bumper/grille |
hay that souds great i beed a body straight frame just totaled mine frames bent body knock off eveny thing else i good what r you asking for what you have left and do you have a title
:-banghead |
hey fastcat i sent you a visitor message.
I'll take $400 for it as it sits with no motor/trans/t-case... I'll sell it to you rolling, it has good front and rear axles 3.55 limited slip, frame is good, tailgate is good, right front fender is good. $400 it's yours and you bring your own wheels and tires to swap on because for $400 these brand new tires ain't going with it. Call - 856-678-7883 Where you locateD? |
sound like DEal i live nere dover del where is the bronoc at and do you still have the title
I have a clear title for the bronco.
I'm 5 minutes from the Delaware Memorial bridge. pennsville, new jersey 08070 Last time i went to Dover it took me about 1 hr and 15 min. Call- 856-693-0918 David |
