Awesome. Do post up as I'm looking at doing a supercab too so want to see how it goes & how it may differ from this crew cab one.
Originally Posted by 79 Crewcab 4x4
(Post 11718536)
AC is going to be tight, get there when i get there. Going to be a combination of an aftermarket under dash assembly, the 7.3 compressor system, and going to have to find/build a rad for up front. I have the interior stuff already, but haven't put much thought into the rad yet... not my biggest concern at this time. Might be a big enough pain I won't put it in but only time will tell.
On the plus side I got bored the other day and cut out the firewall and welded the panel I had made for the computer. Little tighter than I had planned but not bad for eye-balling it. Theory goes I can run all the wiring now and get it running again..... found a 94ish stepside box that's cheap..... NO I dont' like it and no I don't plan on running it for long but I'm having a hard time finding shortbox to replace old one so... I'd rather drive it all uglied up with the stepside than have it sitting waiting for a box. |
https://www.ford-trucks.com/forums/1...body-swap.html
This will be my build thread love your work and hopefully we can swap some info. |
Is it True?(no mean to overtake thread guys)
Originally Posted by thefordlane
(Post 8699815)
im not completly sure with the 4 door pickups. But me and a freind of mine took his 1970 ford f250 2wd and put it on a 1985 ford 4wd frame and everything bolted right up. From the info he found when he did his swap that any ford will fit any ford ford frame taking into acount that it is the same cab and box lenght.
Break out a tape measure. Shouldn't take more than 10 min
Measure, measure, and measure some more.
If i remember correctlly, Your gonna find the 70's chassis is narrower than the 80's chassis. Can u put the 80's body on the 70's chassis, sure. Will it all bolt right up, nope. |
makes sense
Just to clarify guys, im wanting to put a 70's cab and bed on a 80's chassis, and i measured the 1984 F350 IDI, but the 1970 F250 is in Ohio, a ways away from me, so ive been trying to find diagrams or websites that mite have the measurements of the body and chassis that way. i havent bought anything yet, trying to do my research first. again anything anyone knows about this is greatly appreciated guys, thanks
While I haven't done it, from everything I've seen & read (aside from the 1 post you quoted) it will NOT bolt up. Frames are different widths & have bumps/rises, whatever you want to call them in different spots.
Go back & re-read this thread. This 96 frame is going to be VERY similar to the 80's frame you want to use. Another good thread for you would be this one: it has a bunch of pics too & talks about a ’76 supercab body on ’91 supercab frame https://www.ford-trucks.com/forums/1...body-swap.html |
Not much new to report. Am looking to get rid of my 08 f350 scsb 4x so I bought a 78 rclb f250 4x to drive instead but quickly realized that the rc part annoyed me so bought a 78 sclb f250 2x4 and decided that the 155" wb annoyed me about the same so. . . . Yup. Building a 78 scsb f250 4x4. Read tons of articles on here about cutting a lb to sb and have decided on a different method than I have found. Can't find a decent sb around here so going to have to make a few.
Where you at? My short bed may be for sale but it's a 2wd. I think I'd convert 2wd to 4wd before I cut a frame. I'm just weird like that though & not a fan of cutting frames.
Originally Posted by ChaseTruck754
(Post 12200229)
you won't want it (especially if you think your rear bumper was beat!). it's an '87 bed that is ok but not great. The stock bed was beat up pretty badly around both tail light areas & I was going to be putting fiberglass bedsides on it anyways so I let the stock bed go to a guy who was going to take the time to fix it. He gave me the '87 bed and some cash. I was happy.
I'm in Canada.
Not cutting frame. Swapping sc onto rc frame and cutting the box |
good plan. It's about how I want to do it. I've been looking at putting a supercab with a bronco back end on a std. cab, long bed frame or a crew cab with super short bed on the same frame.
Supercab short bed wheel base is 6" longer than a standard cab, long bed so you just cut 6" outta the bed (which you probably know already). I have a pic of one I found on here somewhere. |
Started pulling dents out of the box I found for it today....
