Whats The Best Way To Level Truck?
1995 F150 5.0 4x4. I hate the front end sagging when the truck is parked on a level spot. Any suggestions on what I can do to level. Buddy suggested poly coil spring spacers?
PLEASE HELP!:D Thanks |
i wouldnt go with spring spacers. i would just spend the little extra money and get lift coil springs. but what you need to know is, depending on how much you lift the front end, you may need taller shocks. spacing the spring will hyper-extend the shocks for long periods of time, causing them to go bad. this will make the front end bounce
