1984 Bronco II Auto Transmission Problems
I picked up a 1984 bronco II (A4LD) yesterday for $500 with another one as a parts rig too, good deal is you ask me!
So, I spent today getting the rig that had a good engine and transmission in it going. Changed Oil, coolant, and warmed it up. Problem: Only 1st gear when shifted into OD and D, but if I select 2 then I have first and second gear shifting. I know nothing about these transmissions but have had to trouble shoot my E4OD before so I'm used to Ford transmission querks. How do these transmissions function, is it vacuum or electronic? And, any ideas on where to start looking to troubleshoot this problem? The fluid level was pretty low so I spent a bit of time filling it up, the Previous Owner swapped engines so I'm pretty sure some fluid got spilled out somewhere in the process. Any pointers would be great! |
If you have an '84 with an A4LD, it must've been swapped into it. The A4LD didn't come in a BII until the '85 model year:
Ford Ranger Automatic Transmission Identification LMC Truck Parts - Page 8 LMC Truck Parts - Page 112 Now, in regards to your question: Both the C5 and early A4LD had a vacuum modulator. Sounds as if either your transmission is low on fluid or the modulator might be bad. Another possibility is bands out of adjustment. Ford C5 Automatic Transmission Diagnosis Ford Ranger A4LD Automatic Transmission http://www.therangerstation.com/tech...4LD_manual.pdf |
Thanks, I'll have to check into it in when I get some time between classes in the next day or so. I double checked the titles again, this one is a 86, it's the parts rig that's an 84.
I'll look into the vacuum modulator, it seems be a reoccurring problem after I sifted through a bunch of posts. |
Loose the C-5 and swap to a Toyo Kyogo or Mazda 5spd manual...........FAR more reliable, stronger, more fun to drive and gets the most power out of the 2.8 V6.........Heck, I even know someone who has one taking up space in his garage!!!
I'd love to swap to a manual but it's a bit spendy for my college student budget right now. Maybe in the future, but troubleshooting the Auto is the first task, if I can find something simple that would be great, but if it means rebuild then 5spd might be the cheaper option. Where are you located abouts?
Fluid filled but no difference. I'll have to check out the vacuum regulator on the weekend, might have to get the Cat out of the way to check things out. |
An '86 with an '84 parts truck? Oh that could be interesting... since they share very few common parts :( If you find a need to sell the '84, let me know, I'll be needing an '84/'85 parts vehicle not too far down the road.....
osufireman.........is that osu Oregon state U?........if so, I am within 60 miles.
His profile says "OR"... so, I'd assume Oregon ;) :) That'd be a bit far for me, since I'll be returning to TX :(
Yes, OSU stands for Oregon State University, I'm a Business student there.
So, tinkered with the old gal today. I found out that the vacuum line to the vacuum diaphragm....wasn't hooked up...:-banghead The guy that swapped the new engine into it must not have hooked it up when they did the swap. I know he got it in and then left it at that. Test drove it and it shifts in all gears smoothly and no slipping or harshness, yay! And, I double checked the titles for both rigs, they're both 1986. I started scratching my head after I mentioned the parts being an 84, then looked in the hood and saw a 2.9L...then realized I was wrong. |
That'll definitely make life easier as far as swapping parts! Glad to hear you found the problem. I'd suggest getting an external transmission cooler and changing your transmission fluid & filter once a year.
Originally Posted by kernel-panic
(Post 8624365)
... and I'll add to that, when it does come time to rebuild the A4LD.... you'll want a heavy duty rebuild, NOT just a soft parts replacement. The heavy duty rebuild replaces pieces and parts in the early A4LDs that are prone to failure, etc. with later-model parts. Most people look for 'newer' 4x4 models out of a 1st gen Explorer, but the problem with that involves the differences in number of solenoids, etc. There's workarounds for it, but I forget exact specifics.
I just realized, my TK-5 manual would not work on a 86 to begin with. 83-85 external slave cyl.........86 and up internal slave cyl......mine is from a 85 BII.
Originally Posted by Old93junk
(Post 8624487)
*- I believe the M5 replaced the TK in '88-up applications. There's also a way to swap in a 4.0 M5 clutch to the older TK and FM transmission-equipped trucks. I just don't have a link or the parts list handy right now ;) http://www.therangerstation.com/tech...nsmission.html |
(Post 8613955)
