Ford Truck Enthusiasts Forums
-   1999 - 2003 7.3L Power Stroke Diesel (https://www.ford-trucks.com/forums/forum31/)
-   -   Towing in overdrive ? (https://www.ford-trucks.com/forums/935173-towing-in-overdrive.html)
crazymut 02-28-2010 11:33 PM
I was wondering what everyone thought about towing a travel trailer, 8k lbs, in overdrive while traveling on flat hiways? Is it not a good idea? Or if I watch my trans temp am I ok?
Tenn01PSD350 02-28-2010 11:41 PM
As long as the TC is locked up and the tranny is not hunting, I say go for it. Keep an eye on EGTs too.
Pocket 02-28-2010 11:42 PM
You can tow in overdrive all day long every day, and it won't hurt a thing.
If it's gear hunting, then lock it out of overdrive. The gear hunting under load is what hurts the trans.
crazymut 02-28-2010 11:48 PM
Thanks for your responses. It is not a stock trans either, it's a John Woods towmaster trans.
big poppa 02-28-2010 11:54 PM
Then your more than covered with that trans Terry but I tow my TT in OD(stock) and watch with the gear searching. Like Curtis said, all day long..
yamaguy 02-28-2010 11:55 PM
I usually hold it out of od till i know that I'll be above 50 mph for more than a mile then I'll let it shift it into od. I will hold it out if it hunting Also like others said. My stock trans lasted 290k of heavy towing and snowplowing.
crazymut 03-01-2010 12:03 AM
I did try it today for awhile on my way home from camping once I was out of the hills on straight flat roads. I did notice a drop of about 5 degrees on the trans. I didn't look at the egt's since the engine was only at 1900 instead of 2500 now.
dn29626 03-01-2010 05:07 PM
I tow with with OD and cruise control on.
I made an 80 mile round trip doing it again today.
sflem849 03-01-2010 07:44 PM
I very rarely two in D. Like they said, as long as it is not hunting for gears I let it be. If it is hunting gears I try and control it with that skinny pedal on the right before I take it out of OD.
Ponyboychris 03-01-2010 07:57 PM
I think you got your answer but another yes vote for towing in OD as long as you keep the RPM's around 1800-2000. That's my truck's sweet spot for power/low EGT's.
crazymut 03-02-2010 12:24 AM
That was the rpm range I found to seem like a sweet spot also. Cruising at about 63 to 65 mph. It also seemed to almost be running easier than normal driving without a trailer.
danskool 03-02-2010 03:44 AM
My RPM sweet spot. 2k about 67 MPH. Pulling 10k 5th wheel. In OD. On Cruise.
I will bump off cruise when i see boost gauge rising.. About 10-12psi it likes to kick out of OD and scare the crap out of us.. Want to make a mode up for that some day. Seems that 10-12psi is consistent to cause the trans to kick out of OD. My EGT will never go above 1200.
Kajtek1 03-02-2010 10:32 AM
As said, there is nothing wrong with towing on OD, but it doesn't mean it has to be the best way.
I did tow a trailer with a vehicle that had trip computer showing instant mpg.
Having 5 speed auto -I was playing with it being bored driving with low speed limit in CA.
On some occasions dropping a gear was bringing increase in mpg -also giving much better response when I needed it. Following tall semi could give me 15% increase, but that is tiring.
aklim 03-02-2010 12:11 PM
The trip computer isn't considered really accurate at all. Hence it is referred to as the "lie-o-meter"
spdmpo 03-02-2010 01:38 PM
That's one of the great benefits of having a custom tuner with tow tunes. It won't shift into OD until there's a certain mph that's met. I know mine won't shift to OD in my tow tunes until I get to over 55mph, and then it still won't shift into OD if I'm still accelerating or have a significant load on the TPS, such as pulling a small grade. Very nice.
