distributor
Hey guys . I was wondering , I have a 1979 f250 4x4 with a 351m, it has the small distributor cap, and any I have seen have the small cap as well, yet when I go into a parts store such as Napa , their books say it should have the big cap. You guys with 'm' motors which distributor cap does yours have and what year is it? Thanks
Originally Posted by rob8210
(Post 8539553)
The same V8 distributor cap is used on all 1977/79 Passenger Cars, F100/350's, Bronco's & Econolines, regardless of what size the engine is > > E2ZZ12106A .. Distributor Cap (Motorcraft DH411). This cap is grey. E2ZZ12A217A .. Base Adapter (Motorcraft DJ6) / Use w/E2ZZ12106A Dist Cap. ----------------------------------------------------------------------------- D5AZ12106A .. Distributor Cap (Motorcraft DH354). This cap is blue. Fits: All 1975/76 V8's. ---------------------- B7A12106A .. Distributor Cap (Motorcraft DH6). This cap is black. Fits: All 1957/74 V8's. D5AZ12106A can be used in place of B7A12106A and vice versa. D5AZ12106A replaced B7AZ12106A, which was the (brown) HiPo dist. cap used from 1957 thru 1973. |
Thanks Bill. I always enjoy reading your posts, you have way too much valuable info. Is there a parts catalogue on disk that you would recommend? Unfortunately for me the local dealers all threw out their catalogues before 1980 and I've been lucky enough to have meet 1 older parts guy who has a lot of the older stuff in his memory.
(Post 8539657)
Unfortunately for me the local dealers all threw out their catalogues before 1980 and I've been lucky enough to have meet 1 older parts guy who has a lot of the older stuff in his memory. If you have a Bronco: The 1973/79 Ford Passenger Car Parts Catalog is available on a CD from hipoparts.com. Believe it...or not...Bronco parts are listed in the Ford Passenger Car Parts Catalogs from 1966 thru 1979. :-X15 |
(Post 8539913)
E2ZZ12A217A .. Base Adapter (Motorcraft DJ6) / Use w/E2ZZ12106A Dist Cap. ----------------------------------------------------------------------------- D5AZ12106A .. Distributor Cap (Motorcraft DH354). This cap is blue.. :-X15 I never understood this cap and adapter thing, always seems like there is more play in the unit that way why isn't it 1 unit? |
Originally Posted by spudgunman
(Post 8540138)
so is the D5AZ12106A a cap and adapter?
Nope. I never understood this cap and adapter thing, always seems like there is more play in the unit that way why isn't it 1 unit? The dizzy used beginning in 1977 isn't the same as prior years, either. |
but why? why not 1 part? I dont understand it seems more prone to problems
