need help decoding some codes..
Hello, All,
I nedd a little help decoding some of the codes on the information plate on my truck.. the first.... Axle code 17-J... the second..... D.S.O. code... 1975-14 any help is greatly appricaited 1975 F100, 302 V8, auto |
I know DSO 14 for the Pittsburgh District...I'll try to get back to you on the axle.
Pat |
Everything listed for 75 in the Ford Redbook I have....
Chapter 30- 1975 Ford Truck PRODUCTION 97D Ranchero 500 8,778 97R Ranchero GT 6,114 97K Ranchero Squire 1,549 Bronco 11,273 Courier 56,073 F-100 F-150 F-250 F-350 80 Platform - - - - 80 Platform 4x4 - - - - 81 Chassis-cab - - - - 81 Chassis-cab 4x4 - - - - 83 Flareside Pickup - - - - 83 Flareside Pickup 4x4 - - - - 83 Styleside Pickup 173,975 80,917 86,106 41,616 83 Styleside Pickup 4x4 37,297 - 47,226 - 84 SuperCab Pickup 16,792 20,958 29,622 2,816 84 Chassis-cowl - - - - 85 Chassis-windshield - - - - 86 Stake - - - - 86 Stake 4x4 - - - - Total 228,064 101,875 177,22 44,432 No production breakouts are available for other Light Duty models SERIAL NUMBERS DESCRIPTION F10BU100001 F10-Series identification. F10- F-100, F11-F-100 4x4, F15-F-150 F25-F-250, F26-F250 4x4, F35-F350, U15-Bronco Wagon, X10-F-100 Supercab, X15-F-150 SuperCab X25-F-250 SuperCab, X26-F-250 4x4 SuperCab, X35-F-350 Supercab B- Engine: B- 300 c.i. 6 cyl. H-390 c.i. V-8 M-390 c.i. 4bbl V-8 G-302 c.i. V-8, Y-360 c.i. V-8, J-460 c.i. V-8 U-Assembly plant code 1956-1979 Atlanta, GA A Oakville, CAN B* Chester, PA C Ontario Truck C* Dallas, TX D Mahwah, NJ E* Dearborn, MI F Chicago, IL G Lorain, OH H* Los Angeles, CA J Kansas City, KS K* Michigan Truck L* Norfolk, VA N* Twin Cities, MN P* San Jose, CA R* Allen Park, MI S* Metuchen, NJ T Louisville, KY U* Kentucky Truck V* Wayne, MI W St. Thomas, CAN X Wixom, MI Y St. Louis, MO Z *Trucks 100001-Consecutive Sequence Number-V20,001-X40,000 RANCHERO 5L47H100001 5-Last digit of model year, 5-1976 L-Assembly plant code, see appendix 47-Model code, 47-Ranchero 500,48-Ranchero GT, 49-Ranchero Squire H-Engine. H-351 c.i. V-8, S-400 c.i. V8, A-460 c.i.V-8 100001-Consecutive Sequence Number RATING PLATE PRODUCTION DATE CODE - See appendix RATING PLATE DSO CODE - See down farther.. LOCATION Serial number located on rating plate which is attached on rear face of driver's door. BODY CODES-The first two digits indicate trim color and seat/material type code(see below) and the third digit indicates back of cab Body Type: 3 Flairside Pickup 4 Styleside Pickup D Styleside Crew Cab M SuperCab Pickup 5 Platform/Rack 7 Cowl less windshield 8 Chassis-cab G Chassis-cab Crew Cab P Chassis-cab SuperCab 9 Platform MODEL & GVW CODES F-105 5,100 F-106 5,350 F-107 5,500 F-108 5,700 F-110 4x4 5,250 F-111 4x4 5,350 F-112 4x4 5,000 F-113 4x4 5,700 F-150 6,050 F-251 6,900 F-252 7,500 F-253 8,100 F-255 7,800 F-256 6,350 F-257 6,600 F-260 4x4 6,500 F-261 4x4 7,100 F-262 4x4 7,700 F-263 4x4 7,100 F-264 4x4 7,700 F-350 6,600 F-351 8,000 F-353 8,350 F-354 9,000 F-356 10,000 F-358 9,300 U-150 Bronco wagon U-151 Bronco wagon U-152 Bronco wagon HD ENGINE CODES TRUCKS B - 300 c.i. I-6 1bbl 120hp G - 302 c.i. V-8 2bbl 154hp Y - 360 c.i. V-8 2bbl 196hp H - 390 c.i. V-8 2bbl 201hp M - 390 c.i. V-8 4bbl J - 460 c.i. V-8 4bbl 239hp RANCHERO H - 351 c.i. V-8 2bbl 148hp S - 400 c.i. V-8 2bbl 158hp A - 460 c.i. V-8 4bbl 218hp TRANSMISSION CODES F-SERIES Four speed manual A Three speed manual C Three speed manual HD E Four speed manual F Three speed automatic G Four speed manual P RANCHERO C-6 three speed automatic U REAR AXLE CODES TRUCKS & BRONCO 3.00:1 02,14 3.25:1 10,15,17 3.50:1 B8,B9,H2,08,11,16,18 3.54:1 C7,G1 3.70:1 A2,09,12 3.73:1 D6,C8 4.10:1 B4,D7,G3, 4.11:1 A3,H3,03,05 4.57:1 04 REAR AXLE CODES-RANCHERO 2.75:1 K 2.79:1 L 3.00:1 6,0 3.07:1 E 3.25:1 9,R 3.50:1 S EXTERIOR COLOR CODES TRUCKS Black A Light Blue B Ginger Bronze D Med. Blue Met. E Dk.Ginger Met. F Chrome Yellow G Brt.Med.Blue I Tan (Buff) K White M Lt. Med. Pine N Dk. Green O Med. Ginger Met. R Red T Light Green U Med.Green Gold Y Copper Metallic Z Coral 3 Bright Red 6 Dark Yellow/Green Met. 8 RANCHERO Bright Red 2B Dark Red 2M Medium Blue Metallic 3D Bright Dark Blue Metallic 3G Silver Blue Metallic 3M Pastel Blue 3Q Green Metallic 4T Dark Yellow Green Metallic 4V Dark Copper Metallic 5Y Saddle Bronze Metallic 5T Tan Metallic 5U Pastel Yellow 6E Medium Dark Gold Metallic 6M White 9A Light Green 47 Ginger Bronze Metallic 51 INTERIOR TRIM CODES-TRUCKS Lt.Blue/Med.Blue 2,25,26 Black/Blue 2B,2E,2F,BB,BE,BF,KB,KE,KF Medium Blue 2V,2W,22,23,27,28,B,B3,B5,B6,B7,B8,K,KN, KD,KO,KR,K3,K5,K6,K7,K8 Black/Ginger 3B,3E,3F,CB,CE,CF,LB,LE,LF Lt.Ginger/Med.Ginger 3V,3W,32,33,37,38,C,C3,L3,L7,L8 Black 4,4B,4E,4F,4V,4W,4Z,43,45,46,47,48,D,DB, DE,DF,D3,D5,D6,D7,D8,M,MB,ME,MF,MN,NO,NR M3,M5,M6,M7,M8 Med.Red/Dk.Red 5,53,55,56,63,E,E3,N3 Black/Red 5B,5E,5F,5Z,EB,NB Lt.Green/Med.Green 6,65,66 Black/Green 6B,6E,6F,FB,FE,FF,OB,OE,OF Medium Green 6V,6W,62,67,68,F,F3,F5,F6,F7,F8,O,ON,OO, OR,O3,O5,O6,O7,O8 Medium Ginger C,C5,C6,C7,C8,L,LM,LD,LR,L5,L6 Coral S Tan T Dark Red U BRONCO Parchment 3,34 Blue B,B4 Ginger C,C4 Green F,F4 RANCHERO Black BA,CA,DA,EA,FA,GA Blue BB,CB,DB,EB,FB,GB,MB Green BG,CG,FG,GG,MG,DG Tan BU,CU,DU,EU,FU,GU,MU Saddle F2,G2 White/Blue CQ,DQ,EQ,GQ White/Black CW,DW,EW,GW White/Green C5,D5,E5,G5 White/Saddle C9,D9,E9,G9 PRICES & OPTIONS 97D Ranchero 500 4,049 97R Ranchero GT 4,381 97K Ranchero Squire 4,407 98 Bronco Wagon 4,979 Courier Pickup 3,146 BODY STYLE F-100 F-150 F-250 F-350 80 Platform - - - 3,873 80 Platform(12') - - - 4,875 81 Chassis-cab 3,487 3,849 3,410 3,510 81 Chassis-SuperCab 4,079 4,387 81 Chassis-crew cab - - 4,229 4,363 83 Flareside Pickup(6-3/4') 3,640 - - - 83 Flareside Pickup 3,676 4,002 3,564 - 83 Styleside Pickup(6-3/4') 3,640 - - - 83 Styleside Pickup 3,676 4,002 3,564 3,958 83 SuperCab Pickup(6-3/4') 4,233 4,541 - - 83 SuperCab Pickup 4,229 4,644 4,473 5,070 83 Crew cab Pickup - - 4,371 4,514 86 Stake - - - 3,912 86 Stake(12') - - - 5,115 MAJOR OPTIONS 302 c.i. V-8 Engine 360 c.i. V-8 Engine 390 c.i. V-8 Engine 460 c.i. V-8 Engine 3 speed transmission HD 3 speed transmission OD 4 speed transmission Cruise-O-Matic automatic transmission Four-wheel drive Traction-Lok rear axle Heavy duty clutch Rear shock absorbers (F-350) Power steering Power front disc brakes SelectAire conditioning Heavy duty front springs Heavy duty two-stage rear springs Dual rear wheels Heavy duty wheels Mag style wheel covers Flip open side windows(SuperCab) Dual tape stripes Electric Power Pack Chrome front bumper Rear bumper Rear chrome bumper (Styleside) Splash guards Ranger package Ranger XLT package Convenience Package Northland Special Spare tire lock and chain Tinted windshield Tinted glass Front tow hooks Sliding rear window Heavy duty clutch Heavy duty battery Heavy duty alternator Extra cooling radiator Super Cooling Package Heavy duty fan AM radio AM/FM Stereo radio Cigar lighter Whitewall tires Tinted windshield Ammeter and Oil pressure gauge Outside rearview mirror Remote control outside rearview mirror Outside left or right Western Mirrors Outside left or right non-telescopic mirror Gas tank locking cap Two tone paint Styleside exterior moldings Left or right storage compartment 1975 FACTS No styling changes were made on the F-Series trucks in 1975. There were some interior trim and upholstery revisions. A new model was the F-150, rated at 6050 GVW. Similar to the F-100, it came with heavier springs and axles. Standard engine was the 300 c.i. six cylinder, with the 360,390 and 460 c.i. V-8s optional. As with all other F-Series trucks, power front disc brakes were standard equipment. The F-150 was available only on the 133" wheelbase as well as 139/155" wheelbase SuperCabs. Also new were the chassis-cab SuperCabs. F-100 SuperCabs could now me outfitted with the 300 c.i. six and 390 c.i. 2bbl V-8 in addition to the 360 c.i. V-8. The 240 c.i. engine was no longer available. The 300 ci. six became standard equipment. Due to Federal regulations, trucks with a GVW of less than 6,000 lbs. had to use unleaded gasoline as well as a catalytic converter. Models over 6,000 lbs. could use regular leaded gasoline. As in previous years, the following packages were available- The Northland Special, Ranger and Ranger XLT. The Ranger was not available on Crew Cabs. A new option package was the Custom Decor Group, for Regular and SuperCab pickups. It included knitted vinyl seat upholstery, color keyed floor mats, insulation and bright windshield, rear window, and drip rail moldings and bright hubcaps. The hubcaps weren't available with F-100 4x4s. There were no exterior changes on the Ranchero. Standard equipment now included power steering, power brakes and the automatic transmission. Engine availability was limited to the 351M V-8 with the 400 and 460 c.i. V-8s optional. All Rancheros were fitted with catalytic converters, electronic ignition and single exhaust systems. The Bronco was unchanged as well, but received several mechanical improvements and changes. Foremost was the use of a catalytic converter. The Courier was unchanged as well. That is the typical DSO explanation found in Ford shop manuals. A DSO is an internal Ford production code which groups batches of similarly equipped trucks to be built at the same time so that the specific parts used would be correctly scheduled to be on the assembly line as this group of trucks was rolling down the line. Thus a group of F-150 trucks destined for use by a particular Utility company would get a specific DSO number plus the two digit code for which the Utility is located. Listed below are the District Codes: DISTRICT CODE Boston 11 Buffalo 12 New York 13 Pittsburgh 14 Newark 15 Philadelphia 16 Washington 17 Atlanta 21 Charlotte 22 Jacksonville 24 Richmond 25 New Orleans 26 Cincinnati 27 Louisville 28 Cleveland 32 Detroit 33 Indianapolis 34 Lansing 35 Louisville 36 Buffalo 37 Pittsburgh 38 Chicago 41 Cleveland 42 Milwaukee 43 Twin Cities 44 Davenport 45 Lansing 45 Indianapolis 46 Cincinnati 47 Detroit 48 Denver 51 Des Moines 52 Dallas 52 Kansas City 53 Omaha 54 St. Louis 55 Davenport 56 Houston 57 Twin Cities 58 Dallas 61 Houston 62 Memphis 63 New Orleans 64 Oklahoma City 65 Los Angeles 71 San Jose 72 Salt Lake City 73 Seattle 74 Phoenix 75 Denver 76 Government 83 Home Office Reserve 84 American Red Cross 85 Body Company 87 Transportation Service 89 Export 90-99 FORD OF CANADA Central B1 Eastern B2 Atlantic B3 Midwestern B4 Western B6 Pacific B7 Great Lakes B8 Export 11-17 |
Ok thanks.. strange thing though.. my truck was assembled in Canada.. and ended up in Pittsburgh, PA....Was it common for trucks built in Ontario to end up here?
I dont think it mattered much then, when something came off the line they shipped it were ever it was needed.....
build sheet
Hello I would like to know the original color of my truck it was a special order and when I had the seat out I found the build sheet between the lower springs and foam, but the paint code is blank on that too. Any advise?
