Went from this,
https://cimg6.ibsrv.net/gimg/www.for...3287dbacbe.jpg Now I know why the frame and exhaust are that shape... To this in an hour and a half. Felt much longer though. https://cimg2.ibsrv.net/gimg/www.for...9dc01131b7.jpg Bonus points for the eagle eyed! |
Originally Posted by Daveycracky
(Post 16872670)
My 75 had run cold since I bought it. Now that it's particularly cold, she has been idling rough, barely enough heat to defrost the windows, and spitting carbon juice from the tailpipe with a heavy smell of gas. I changed out the thermostat today and solved all these problems for twenty bucks and a six pack. The working part was done before the end of the first quarter of the Packers/Cowboys game. By the end of that sweet fight, no more carbon juice, temp gauge is centered with a 190 deg tstat, the heater rocks, and a noticeably smoother idle. The ride home involved a freeway run and the throttle response is way better in all aspects, including uphill (which had been dropping off as ambient temps had been dropping).
Big win for the new kid. |
(Post 16858442)
What did you use to reinforce them on the back side?
https://cimg1.ibsrv.net/gimg/www.for...540a50e4ed.jpg |
Today I changed out my speedometer driven gear. The truck has a three-speed manual with a 3.00:1 rear end, but someone put 235/75/15s on there, and I think they are taller than what Henry first put on it 40 years ago.
I'd had the gear out when I first got the truck, and was ferreting out the cause of my non-working speedo. (Disconnected at the head.) When I had it out, I saw that it was an off-white color, so I assumed it was the same as the one I saved from my old '92 Mustang GT. I had one other extra driven gear, so today I went ahead and pulled the cable out of the trans, and removed the gear. The truck's gear is more of a tan color and has 19 teeth. The gear from the Mustang has 18 teeth and they are pitched in the correct direction, so I figured it was at least a step in the right direction. It is an off-white color too. Side by side, the one of them looked yellow compared to the other. I made sure the teeth were facing the same direction and put it on the cable and into the trans, and went for a short drive., Now my speedo seems much more accurate. It registered about 8 MPH slow before, but now seems to read slightly fast. I'll have a better idea of its accuracy when I drive it farther, and on the highway. |
Originally Posted by Djstright
(Post 16867911)
Well I finally got around to painting the oil cap and the white on the valve covers. https://cimg6.ibsrv.net/gimg/www.for...2c18871737.jpg
Originally Posted by Lds79ford
(Post 16885142)
they look awesome
Started ol red and let it idle for a while and then did a couple throttle blips and enjoyed the headers with header glass packs...
(Post 16885142)
they look awesome
https://cimg3.ibsrv.net/gimg/www.for...2420473ab1.jpg |
Ok let me see if I can even get close on what RC and I accomplished today on Bullet...
Heater and radio brackets installed with radio and heater. (Heater hooked up) Old fuel lines ripped out Bumper all tightened down (rear) Front bumper tightened down Light and windshield wiper switches in Bunch of brackets torched off Torched off two bad rear shocks Took a worthless step off Grommet on valve cover New heater hoses installed RC spent some time figuring out wiring for a newer dash cluster... Not me lol |
Pulled the hood and replaced the missing captive nuts. Reinstalled and aligned the hood
https://cimg5.ibsrv.net/gimg/www.for...4587f87950.jpg |
Pumped up the flat tire...
I've been out and at least playing with Ka'Bluey this last couple of weeks.:o
He's not too far from another truck ride himself, well in the next few months anyway. We're moving back home to Southern Missouri this spring/summer, so he's getting transported again back to the same friends Alan, and Tiff to be truck sat until we get back home.:-X03 Then with the great group that we have in Missouri, I'm hopeful that he'll have some new blue paint on him, inside and out in the next year:-X22 Unk Bob:-wink |
Kicked the fender and about 5 pounds of salty mud hit the ground. Damn CT winter roads and their stupid salt.
Drove my 79 to work and daydreamt about how I want to build my 2 78's and 75.
Well I got the flywheel back from the machine shop and ordered a ton of new parts including a new heavy duty clutch and water pump. Now the entire cooling system will be new. https://cimg9.ibsrv.net/gimg/www.for...0f5ff1a658.jpg
