dried it off, again! until I can make room in the man cave for the truck and the Harley (CVO) the truck has to stay outside, and had another "blonde moment" yesterday, never open the hood with the hood has water all over it! dump asker! got to clean the motor all over again to!
https://cimg9.ibsrv.net/gimg/www.for...2c714da55.jpeg
Primed my hood today. It looks all splotchy but that is just the shadow of the trees. |
Just finished the drivers side fender and primed it. My goal for tomorrow is to have the cowl done, or maybe a door.
It was a sad day.
Sent the Title to the new owner in Florida. You may see him on here eventually.
On a brighter note... Going to pick up my 2016 F250 FX4 Lariat this weekend! |
Redid vinyl and painting rims
Drove it to a junk yard that was pretty much untouched for decades until recently and got all this for a sweet deal.
https://www.supermotors.net/getfile/..._202241500.jpg https://www.supermotors.net/getfile/..._203056219.jpg Black xlt door panels from 76 f100 plus map pockets no broken tabs. supercab headliner chrome trim 2 delay wiper modules 1 delay wiper switch 4 window cranks 78/79 bumper brace 78/79 factory ac ducting 73-77 wood grain horn pad rear side marker light cruise control module and wiring 78/79 tilt auto column driverside black sun visor slide out spare tire carrier latch bracket to go with my extra slide out carrier I found in the mountains in the middle of no-where factory ac condensate drip tube oem radio and speaker wire harness oem lug wrench 76 ranger xlt glove box door passenger door racetrack trim 2 passenger door handles dual horn wire harness wiper washer reservoir with heat shield driverside 77-79 wheel well liner chrome center visor holder piece metal dash trim bezel woodgrain all studs intact metal dash trim bezel black broke one stud stainless 73-77 windshield trim Total $135 for all :o They have a 78/79 dana 60 front with sway bar asking $300. I would have picked it up but I didn't have the cash with me. |
Primed the other fender and a door, and started prepping the cab and the drivers door. I would like to have the cab, doors and fenders all done by next week. I will devote a week or two to the bed prep.
Bled brakes, installed aluminum floor door guards(?)
Attempted to tune Carb, but truck won't start |
After a total rewire, checked all lights and started up for the first time since December. Had a puddle of fuel on the garage floor from a leaking line (easy fix). All lights worked properly except front driver's side marker light (under headlight). Left dash turn indicator stays on steady. Bad bulb? Flashers work.
Was able to pull her out of the garage and nose it in so I can start working on some motor stuff. Oh, and put the driver's door back on... |
Originally Posted by Murphy's Law F-150
(Post 16177679)
Was able to pull her out of the garage and nose it in so I can start working on some motor stuff. Oh, and put the driver's door back on... I got a TON done the last couple days. The entire body is primed in dark gray primer and ready for paint. Hopefully by the next update you will see er in blue. https://cimg5.ibsrv.net/gimg/www.for...82209bff1.jpeg https://cimg2.ibsrv.net/gimg/www.for...9159ea28f.jpeg https://cimg7.ibsrv.net/gimg/www.for...6270742cc.jpeg https://cimg9.ibsrv.net/gimg/www.for...912302ed1.jpeg |
New wheels
Mounted up my new to me 14"wide centerline wheels
https://cimg4.ibsrv.net/gimg/www.for...12838207d.jpeg https://cimg5.ibsrv.net/gimg/www.for...8d6a253ec.jpeg https://cimg6.ibsrv.net/gimg/www.for...c9790f136.jpeg |
damn dixie, that's bad asss.
I added freedom stick holder. https://cimg4.ibsrv.net/gimg/www.for...e9b9f5cefa.jpg |
Originally Posted by mountain dewd
(Post 16177916)
Glad she's running! Isn't it a good feeling when your truck lights off after a long nap?
I got a TON done the last couple days. The entire body is primed in dark gray primer and ready for paint. Hopefully by the next update you will see er in blue. https://cimg5.ibsrv.net/gimg/www.for...82209bff1.jpeg https://cimg2.ibsrv.net/gimg/www.for...9159ea28f.jpeg https://cimg7.ibsrv.net/gimg/www.for...6270742cc.jpeg https://cimg9.ibsrv.net/gimg/www.for...912302ed1.jpeg Dang MD, just seems like this mornin I saw a pic of your truck and it was ....well...colorful... you must be feeelin way better now :-jammin looks like you ain't got far to go until color. :-drink |
