need timing specs 302
hi I need help with timing my 86 f150 302 with auto tranny .
what are the specs? i have the 10* BTDC disconnect the spout connector. what about RPM . am i missing any thing else. I do not have the specs sheets or any factory settings . thanks for any help Mike |
It's usually on the radiator support sticker. When you disconnect the spout connector, the rpm doesn't matter, the timing is locked when the computer control is taken away by disconnecting the spout.
